Changing double honk with ids
Old Mar 27, 2017 | 05:37 PM
Mr J 125's Avatar
Mr J 125
So a ford tech I know said he would try to change some settings with the ford ids scan tool he wasn't aware you could change the dpf% with it. My question is are there other setting such as double honk etc that anybody knows of that I can change threw the ids I don't want to use forscan I would rather have dealer do the changes
Old Mar 27, 2017 | 08:24 PM
lifelineamb's Avatar
lifelineamb
I don't have push button on my truck but I do have it on my 16 mustang. I have IDS and was unable to disable the honk using IDS as I couldn't find the option in any of the menus. I was able to turn it off very easily using forscan and I would suggest you do the same. this forum will be very helpful if you decide to do so.
Old Mar 27, 2017 | 08:49 PM
das_16's Avatar
das_16
you need forscan to turn off the double honk.
Old Mar 27, 2017 | 08:57 PM
Mr J 125's Avatar
Mr J 125
Oh really well that's a bummer I was hoping he could, oh well looks like I am just getting the dpf% then lol
Old Mar 27, 2017 | 09:04 PM
Bristol Blue's Avatar
Bristol Blue
I'm just glad to hear that it can be disabled. Heck, I don't care if they charge me- It's very annoying!!!
Old Mar 27, 2017 | 11:57 PM
347Flatty's Avatar
347Flatty
What other changes besides the dpf, tire psi/size can be done at the dealer with IDS?
Old Mar 28, 2017 | 07:27 AM
troverman's Avatar
troverman
Just spend the $80 on the adapter (the software is free) and you can turn off the annoying honk yourself. I've done it on mine...for that mod alone it is worth every penny. You will also be able to read DTC codes for all the individual modules, just like the Ford dealer can...plus more programming.
Old Mar 28, 2017 | 09:25 AM
Mr J 125's Avatar
Mr J 125
I understand the whole forscan thing and what you can do with it but that's not what I wanted to know. I wanted to know what I can change threw the ids scanner
Old Mar 28, 2017 | 09:44 AM
99SuperDuty2017's Avatar
99SuperDuty2017
A quick review on what, and where to order and any cables or accessory that might be needed would be helpful. what do you recommend ? Thanks Troverman.
Old Mar 28, 2017 | 10:01 AM
jackfordsd350's Avatar
jackfordsd350
Looking for members in upstate NY who have done double horn disable. PM if you are willing to meet up. Not interested in doing the whole process for one modification to my truck. Thanks
Old Mar 28, 2017 | 10:02 AM
troverman's Avatar
troverman
*Disclaimer* - There are others on this board significantly smarter than me when it comes to ForScan. EpicCowlick, Karl4Cat, and probably some others come to mind.
That said, here is the link to the adapter on Amazon that I bought, recommended to me by Karl4Cat, which is confirmed to be compatible with all functions:
Amazon Amazon
So basically you need three things to use ForScan:
1. An OBD2 bluetooth adapter which plugs into your vehicle and connects to a computer (like the one in the link above, although some other cheaper versions might also work)
2. A laptop computer equipped with Bluetooth and a Windows operating system (although Windows running on Mac BootCamp will work)
3. The free, ForScan software which can be downloaded at this link:
What's new
You will need to join the ForScan forum in order to get a license key to use the "Extended" features of ForScan. The standard version does not allow programming (such as getting rid of the double horn honk, etc). For now, the Extended license is good for 2 months.
Link the Bluetooth adapter to your laptop in the truck (ignition needs to be on), install the software, use the software link button to connect the software to the Bluetooth device, and you're on your way.
Old Mar 28, 2017 | 10:08 AM
troverman's Avatar
troverman
I'd do it if I was closer. Not sure exactly where you live in NY, but for reference, Albany is about 3 hours or so from me. Rasalas (Rob) might be closer to you, although I have no idea if he uses ForScan.
Given the odd behavior that did happen to my truck after making this change, it would always be good to have the equipment on hand to revert changes if undesirable results occurred down the road.
diamondbackmike2004
Aug 30, 2017 03:34 PM
Christian's1988Ford
2017 Ford SVT F150 Raptor
Apr 28, 2016 05:10 AM
jeremyd72
Jul 4, 2007 12:50 PM
