Filter diagnosis
Old Mar 27, 2017 | 04:30 PM
pwjackson42's Avatar
pwjackson42
Filter diagnosis
here is a picture of my fuel filter maybe 3,000 miles on it.
Long story short I originally thought my injector orings were going bad. After I thought about it more I thought maybe fuel tanks. I just replaced both front and rear (F26E). Could this be the coating on my tanks coming off and getting in there? Anyone else had this happen. Didn't really thing orings because the truck hasn't acted funny.
Old Mar 27, 2017 | 04:41 PM
madpogue's Avatar
madpogue
Do you add anything to your fuel, such as two-cycle oil?
Old Mar 27, 2017 | 06:21 PM
pwjackson42
No just diesel kleen. I am leaning towards the coating on the inside of the fuel tanks because it's a grayish/silver color.
Old Mar 28, 2017 | 03:49 PM
knottyrope's Avatar
knottyrope
Mine looked like that and it was injector orings. Not sure what color diesel clean is.
Old Mar 28, 2017 | 08:05 PM
pwjackson42
Was the fuel in your fuel bowl discolored or grey/black? Mine was clean fuel from what I could tell.
Old Mar 29, 2017 | 08:28 AM
knottyrope's Avatar
knottyrope
my fuel looked clean but the filter was dirty gray like that
O Rings are easy enough to replace with some time under the hood and can be had cheap from Alliant Injector O-rings - Ford 7.3L Powerstroke (94-03)
Old Mar 29, 2017 | 01:37 PM
dclack's Avatar
dclack
When my orings were bad, the filter was completely black, ace of spades black. That filter looks clean compared to what mine looked like.
Old Mar 29, 2017 | 02:09 PM
knottyrope's Avatar
knottyrope
replace filter and check in 3k miles and compare colors
Are you losing engine oil in those 3k miles? if no then maybe it is the tank coating
if you are using oil and have a scanner, check IPR% duty at cold vs hot if it jumps a lot higher hot then you could be having an o ring leak
KPT
6.7L Power Stroke Diesel
Oct 26, 2012 08:57 AM
darren32
101
May 26, 2012 07:44 AM
kper05
Feb 2, 2012 02:00 PM
Glockem45
19
Dec 6, 2009 10:52 AM
greythorn3
Jan 10, 2008 07:39 PM
