Computer compatibility, 91 F150
Old Mar 26, 2017 | 10:08 PM
Bootlegger's Deluxe's Avatar
Bootlegger's Deluxe
hello everyone!
I'm working on my 1991 F150, it came from the factory with a 302/ automatic. I started tearing it apart with plans to rebuild the 302 and swap in a ZF 5 speed, and so i nabbed a donor computer out of a 91 F150, 302/M5od truck.
Now, as the build is progressing into more of a "restomod" type of build, with the body coming off, etc, i am pondering if i should switch to a 351W/ 5 speed combo. I have a 351W already, and i can certainly source the proper parts to mate it to the truck, my question lies with the computer work.
what years do i need to find a computer from to make the truck function? I do have a 95 F250 parts truck that was a 351w/ 5 speed, i dont know if it is compatible, or not really? Also, will the engine wiring harness work with the 351W i have? the Windsor i am planning on using came out of a 95 F150, it was an automatic truck, and yes, it is still speed density, not mass air. i did keep the entire harness from that truck as well, but i dont know if it will do me any good.
someone with more experience care to chime in?
Old Mar 26, 2017 | 11:39 PM
ChRoNo16's Avatar
ChRoNo16
I dont think your harness will work. Yes its all OBD1 so most likely you can use the comp from the truck with the 351 in it.
Old Mar 27, 2017 | 06:45 AM
'89F2urd's Avatar
'89F2urd
Yes the 95 comp will work, assuming it's speed density.
Old Mar 27, 2017 | 07:27 AM
Bootlegger's Deluxe
what underhood harness will i need then? the one from the stock 302 that was in my 91, or the harness that came from a 95?
Old Mar 27, 2017 | 07:42 AM
'89F2urd's Avatar
'89F2urd
Also assuming your f1fiddy is speed density, you change no wiring. Just swap the computer.
Old Mar 27, 2017 | 08:30 AM
Conanski's Avatar
Conanski
+1, keep the original harness intact and adapt the motor to it where necessary. The only place this will be necessary is with the distributor, you will have to modify the 5.8 distributor to accept a TFI module and change the PIP module.
Old Mar 27, 2017 | 10:09 PM
Bootlegger's Deluxe
Well, it sounds like i will be sending the 351W to the machine shop, and the 302 will be heading to my 87 Tbird
Old Mar 28, 2017 | 06:51 AM
'89F2urd's Avatar
'89F2urd
302.
big-ugly
Dec 30, 2011 11:02 AM
hav24wheel
Sep 22, 2010 01:24 PM
deadgary
Jun 6, 2010 10:13 PM
hoxiii
Jan 10, 2006 10:36 PM
johnnyo888
Apr 29, 2005 10:08 PM
