Sponsored by: Auxito
Electrical problems? Witchcraft?
Old Mar 26, 2017 | 01:54 PM
Bomberman's Avatar
Bomberman
Hi all, I recently bought a 2001 F150 SuperCrew with the 4.6 with approximately 250k miles. My battery kept dying (brand new battery, the one that was in it was kaput) and I couldn't figure out why. I took the alternator out and had it tested by my buddy at AutoZone, but it tested good. Anyway my suspicion is that something is draining the battery while the truck is off. I recently discovered that the air sometimes stays on when I kill the engine. Occasionally, I hear a relay clicking under the hood when the truck is off. Any idea what could be causing this? I admit I don't know much about the electrical aspect of these thinga. Also, I don't know if this is related, but my factory stereo sometimes has no power. Any advice/suggestions would be greatly appreciated. Thanks all
Old Mar 26, 2017 | 02:15 PM
projectSHO89's Avatar
projectSHO89
All are common symptoms of what I call "Leaky Windshield Syndrome".
Water drips down into the GEM module and the fuse box under the dash and causes random mischief.
Old Mar 27, 2017 | 09:03 AM
alloro's Avatar
alloro
Alternators can test good on the bench and still fail in the vehicle. On the bench since during the test it is not exposed to the heat, cold, wind, moisture, etc. like what happens in the real world.
By "air" staying on do you mean the blower motor? If that's the case the blower motor is a significant draw and will drain the battery. The clicking relay could be the high speed blower relay if you're hearing it only when the blower turns on.
cadunkle
Oct 17, 2016 08:56 PM
CABGx3
Aug 3, 2010 10:13 PM
gamebird
1997 - 2003 F150
Feb 3, 2005 11:49 AM
morepower16
Electrical Systems/Wiring
Nov 22, 2002 01:07 AM
Katt
May 25, 2001 07:32 PM
