Install & Review: ANZO G2 LED Tail lights
Old 03-26-2017, 01:32 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
So to match my Spyder Headlights I bought some ANZO taillights. These have been called the G2 which I suppose stands for generation 2? It's a new design probably supposed to look like the newer F150s. I think the look goes well with the headlights.
Build quality is acceptable. The housing seems sound, but the inside is cheaper plastic. However, I don't think this will cause any problems. All of the lights are LED. The only small concern is off axis visibility for turn signals because the LEDs are recessed in individual pods. They seem to have anticipated this because there are cutouts on each "pod" towards the outer edge. I don't think this will cause much issue either. If you're using your blinker, the only cars that wouldn't obviously see it are probably going to get a love tap if you try to merge.
The fitment on the truck is very good. The tail and brake lights simply plug in where the old bulb went. The reverse bulb is retained from stock, and the plug didn't fit very well; it took some finesse getting it to seat, but once it was in, it's not going anywhere.
Also, included were some big boxes which I assume we're resistors. I wasn't expecting this, but they include sticky tape, and it was no problem mounting them behind the lights.
ANZO Tail Lights: http://amzn.to/2nOpYKT
LED Reverse Bulb: http://amzn.to/2n0E33p
Old 03-26-2017, 03:16 PM
the_auto_tech's Avatar
the_auto_tech
the_auto_tech is offline
Was always curious how long these would work for. Generally most LED setups don't last because the resistors burn up, and I haven't seen anyone figure out how to disable the hyper flash with the LED's through the factory body control module.
Old 03-29-2017, 10:33 AM
BETCHER78's Avatar
BETCHER78
BETCHER78 is offline
I used to add resistors mainly because in my 09 i had some bleed back when i didnt have at least parking lights on.
resistors fixed that and also made my switch backs work up front. however also back in 09 you can have the ' bulb out warning ' disabled. i cant remmeber where it was at. but its under a section for those who buy trucks. bed delete- and know they will probably have LED's on a flatbed as one example.
i had bulb out warning disabled on my 13, and it works great. im using philips LEDs and it works great.
Old 03-29-2017, 11:32 AM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
The bulb out warning is in the body module and can be disabled or activated with ForScan or Ford IDS, for reference.
Old 04-12-2017, 11:54 PM
the_auto_tech
Just ordered these for my truck. After getting the Spyder headlights I wanted the tail lights to match. Thankfully I've got the stock FX4 tails so they will sell easily!
Old 04-19-2017, 10:39 PM
the_auto_tech
Got the tail lights installed. LOVE them! I also installed LED reverse bulbs too. I didn't install the resistor boxes. If you used FORScan you can disable the bulb out warnings which allows you to run LED's without resistors.
Old 04-20-2017, 08:16 AM
King-bRanch's Avatar
King-bRanch
King-bRanch is offline
I "did" really like my OE FX series Head/Tail Lights.... But those SPYDER Lights are bad*ss
Old 04-23-2017, 09:26 AM
the_auto_tech
Same! I had the FX4 tails but after getting the Spyder headlights I wanted the tail lights that matched them. I also just installed the matching third brake lamp too. Looked really out of place with the stock clear one. lol
Old 04-27-2017, 04:27 PM
Xader's Avatar
Xader
Xader is offline
Ya don't say.
You know, even with the chrome package, the stock taillights just don't look right on my black '09. So if you're not gonna be asking too much for them...
Old 04-29-2017, 10:04 AM
the_auto_tech
Originally Posted by Xader
Ya don't say.
Shoot me a PM if you're interested in them! I am selling them.
Old 12-01-2017, 11:24 PM
Chris Karsseboom's Avatar
Chris Karsseboom
Chris Karsseboom is offline
Projector after market lights suck. The oem are leds are fantastic, Ford is the only truck on the market with them. The oem outer leds look like diamonds glistening. Those aftermarket look like every other eBay setup.
Disordinate
1999 to 2016 Super Duty
10-06-2017 10:44 PM
JimRay
07-08-2017 08:31 PM
Supercab
09-22-2011 11:15 AM
slowmans
05-13-2009 05:49 PM
thenewjohndeere
1978 - 1996 Big Bronco
12-29-2006 10:07 AM
Quick Reply: Install & Review: ANZO G2 LED Tail lights
