Adjusting rear brakes?
Old Mar 25, 2017 | 08:17 AM
good to doo's Avatar
good to doo
So we picked up a 79f150 2wd. We did a brake job on the 9" everything lubed and working proper. So how do we properly adjust the brakes from scratch. I,ve heard that you drive the truck forward then drive in reverse and applie the brakes to set them, do that a number of times I geuss. Thanks for your input.
Old Mar 25, 2017 | 09:16 AM
nakedpancakes's Avatar
nakedpancakes
Well they do self adjust in reverse but i think it's only a little at a time to adjust for wear. But there is a slot inside bottom for adjustment that would be faster way to get them set.
Old Mar 25, 2017 | 09:27 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I adjust the rear brake shoes to slightly drag on the drum when you put it on, and take if off. Then put them on and do a hand spin ck of the drum and listen for a light dragging sound back, adjuster off 1/2 turn.
Old Mar 25, 2017 | 09:32 AM
Tedster9's Avatar
Tedster9
Yep, the initial adjustment must be done manually or they will never self-adjust, ever. The self-adjusters, all they do is take up the slack after the linings start to wear.
Run the adjusters all the way out just as tight as they'll go and then depress the brake pedal a few times to center the shoes and take the slop or clearance out in all the springs and fiddly bits. Then back the adjusters off till the wheel will turn, but with a slight drag. If the wheel spins freely the brake pedal will be low and mushy.
They should work pretty good at that point. Take a test drive around the block and maybe check one more time for wheel drag and adjust again as necessary. Finally take the truck out to a safe lonely stretch of highway where you can make a dozen or so moderate braking cycles in a row from 50 or 60 down to 20, to get the shoes bedded in. Don't glaze the shoes, but they need to get smoking.
Old Mar 25, 2017 | 10:13 AM
beartracks's Avatar
beartracks
If they aren't pretty close manually the adjusters may not pick up the slack.
gthbryce
30
May 24, 2026 12:12 AM
Carloespo
15
Jan 8, 2025 10:58 AM
quakerj
Mar 2, 2015 07:32 AM
GBuckert
Dec 29, 2010 10:07 AM
gregdatech
Apr 9, 2002 07:58 PM
