Compressor wheel for ported housing
Old Mar 27, 2017 | 06:44 AM
Walleye Hunter's Avatar
Walleye Hunter
Yep, you have some soot there. That job rates as one of my least favorites. You speak of slight play. In and out I had none but side to side, top to bottom I had a little. I do believe that the slight side to side, top to bottom is normal as oil circulates around the shaft. If that helps you any.
Old Mar 28, 2017 | 08:49 PM
ScaldedDog's Avatar
ScaldedDog
Dude, if you're still considering this wheel, I've run it for awhile and like it. In my DP 80-ish HP tune I can hit 30psi at 5500ft on the otherwise stock turbo, but I rarely run that tune. I hit 25psi with my various 60HP tunes, and it's quite driveable
I rebuilt the turbo when I installed the new wheel, and documented it here, IIRC.
Mark
Old Mar 28, 2017 | 11:30 PM
Dude-Ford's Avatar
Dude-Ford
Mark
ive got to much crap I wanna do and not enough extra cash! I think I'm still gonna do it while I'm saving for injectors. I can't go a month without doing something to the truck.
Old Mar 28, 2017 | 11:36 PM
Dude-Ford's Avatar
Dude-Ford
Not looking forward to it. Everything I've seen and read about replacing up pipes looks down right frustrating.
Old Mar 29, 2017 | 01:01 PM
hydro man 17's Avatar
hydro man 17
Well if you go with the IH bellowed pipes you can just cut the old ones off and eliminate that grief. Once the new ones are installed you are done - for a long time.
Robert6401
61
Mar 17, 2014 02:44 PM
Fireman_dave
May 31, 2012 03:05 PM
ramtruckman
Mar 15, 2004 07:57 AM
mueckster
Dec 24, 2003 07:07 PM
jwillson4
Jul 28, 2003 01:20 PM
