HELP!!!! Brake problem!
Old Mar 28, 2017 | 09:47 AM
Chulke's Avatar
Chulke
Originally Posted by good to doo
Just try bleeding the one you have. Its new right?.
New 2 years ago according to the PO...and I have no idea what he did exactly. So, I will just replace it and do it correctly that way I know it's done right and everything.
I don't want to take any chances with it.
Old Mar 28, 2017 | 09:50 AM
good to doo's Avatar
good to doo
Yes brakes are the most important part of any vehicle. You will still have to bleed the new master.
Old Mar 28, 2017 | 10:12 AM
Tedster9's Avatar
Tedster9
Originally Posted by Chulke
That is, of course, if someone else has a thought?? I'm all ears. Thanks and cheers to you all!
Brake systems are tough to isolate in terms of "replace this part over here, but leave this 40 year old part over here alone." This is one instance where "might as well" is a good thing. It doesn't make any sense to replace the master cylinder, and not say, the rubber brake hoses. Wheel cylinders aren't expensive either.
Bite the bullet and replace everything but the pedal, (but inspect that too, carefully) if you do the work yourself it's reasonable, just a few hundred bucks.
Trucklover22
13
Oct 22, 2016 08:26 PM
Eric H
Jun 22, 2014 09:32 AM
robjs111
1997 - 2003 F150
Aug 14, 2010 08:11 PM
wresleu
1997 - 2003 F150
Jun 26, 2006 08:08 PM
SpeculatorNY
Jul 27, 2004 10:24 PM
