Np205 problems
Old Mar 24, 2017 | 12:53 PM
77f250highboy's Avatar
77f250highboy
Np205 problems
On my f250 when ever I'm going down the road and pass someone or speed up and let off the gas sometimes it'll put the transfer case into neutral from 2h. So I have to pull off to the side of the road turn it off and put it into 4h and start it then with that tension put back into 2h and get back on. My wheels are out of balance and motor mount needs to be replaced waiting for the money now and will do that but would that cause that problem or what should I be looking at
Old Mar 24, 2017 | 04:29 PM
DB429SCJ's Avatar
DB429SCJ
Replace motor mount and check transmission mount.
Old Mar 24, 2017 | 07:01 PM
77highboy77's Avatar
77highboy77
If this is in the 77 Highboy in your name, check to make sure the transfer case mounts and the rear strut are tight too.
Old Mar 24, 2017 | 07:43 PM
PA74F250's Avatar
PA74F250
My 79 does the same thing and all my mounts are fine and it's married. If yours acts like mine it's so wore it's hard to tell where each gear is. I usually have to play with it a few times to get it to stay in 2wd. I can usually hear it trying to pop out before it does. Once I get it stays for months without issues. Out of the 3 205's we have it's the weirdest one.
Old Mar 25, 2017 | 09:09 AM
lee's Avatar
lee
Hi,
The Dana 24 in my 1970 f-250 would occasionally do this also. It's a result of worn detentes on the shift rods.
I replaced the -24 with a 205 which I rebuilt before install. Rebuild kit came with new ball bearings and springs for the detentes. So far it is operating correctly.
Lee
william16339
Dec 21, 2015 12:43 PM
DarrellJ
Nov 5, 2009 10:40 PM
DutchmanAZ
May 31, 2002 02:42 PM
jimmc
1978 - 1996 Big Bronco
Mar 13, 2001 07:39 AM
