Mechanical fuel pump
Old Mar 24, 2017 | 10:59 AM
Silver54's Avatar
Silver54
Hey all, the diaphragm in our mechanical fuel pump for the 55 with the 239 yblock is about shot, does any one know if one that works on a 272/292 would work as a replacement?
https://www.summitracing.com/int/par...illocation=int
Here is the link.
Just want to know if it would be a waste of money to order this
Old Mar 24, 2017 | 03:27 PM
charliemccraney's Avatar
charliemccraney
The pump mounts to '55 and up timing covers in the same way. So the first thing to do is to verify that it still has a '55 or newer timing cover. The easy way is to look at the fuel pump bolts. 5/16" = 1954. 3/8" = '55 or newer. It is 62 years old so check, do not assume.
If it is '55 or newer, it should bolt up and pump gas. You might have to rework fuel and vacuum lines.
Old Mar 25, 2017 | 08:30 AM
Silver54's Avatar
Silver54
As always Charlie, that's awesome information! We are the 3/8s checked last night after seeing your message, and the lines needed to be reworked anyway as they were rotted.
Thanks for your help!
Silver54
Mar 24, 2017 07:58 AM
cbfomoco
30
Jan 22, 2011 01:22 PM
itzaford
16
Nov 21, 2008 07:39 PM
kwasham
Apr 25, 2005 06:56 PM
f100guy
Sep 5, 2003 09:00 AM
