Column Shifter Help (ND)
Old Mar 23, 2017 | 07:26 PM
eric8's Avatar
eric8
Got the turn signal switch, upper column bearing, and then the column shift bowl off, then see this...a loose snap ring and wave washer. Something doesn't look right. 1976 302, 2wd, 3 on the tree.
Old Mar 23, 2017 | 08:11 PM
eric8's Avatar
eric8
The shift tube that this ring and washer go around will slide right out of the steering column. Is there a bearing that goes here?
Old Mar 23, 2017 | 08:15 PM
eric8's Avatar
eric8
My diagram shows a part in this area. Ref # 7c228? Number Dummy?
Old Mar 24, 2017 | 01:37 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by eric8
My diagram shows a part in this area. Ref # 7C228?
B9AZ-7C228-A .. Transmission Gearshift Lever Socket to Tube Anti-Vibrator Spring Washer / Obsolete
1973/77 F100/250.
KLIMESH MOTOR SALES in Calmar IA has 1 = 563-562-3241.
MCDONALD OBSOLETE PARTS in Rockport IN has 1 = 812-359-4965.
FEYER FORD in Edenton NC has 3 = 252-482-2144.
Old Mar 24, 2017 | 02:47 PM
eric8's Avatar
eric8
Thanks for the info. Not sure what that ring is doing on top of the washer but I'll reassemble it like I found it!
Canus
Dec 12, 2012 10:06 PM
motomation
Nov 10, 2012 11:50 AM
F-250 restorer
Nov 19, 2009 11:29 PM
ron65
Jan 6, 2007 04:06 PM
Matt67
Sep 4, 2001 05:32 AM
