engine swap
Old Mar 23, 2017 | 09:52 AM
Anthony79's Avatar
Anthony79
engine swap
I want to swap out my 400 for a 429 out of a 67 thunder bird. Is this a good idea and can it be done with the bell housing from the 400? How do I find out if the engine out of the thunder bird is a 429?
79 Ford F-250
Old Mar 23, 2017 | 09:58 AM
meangreen92's Avatar
meangreen92
429 didn't come along until '68 or '69. Can you post up pics of the engine and maybe of the whole T-Bird?
Nice truck!
Old Mar 23, 2017 | 10:15 AM
kettle-one's Avatar
kettle-one
^^This. 68 was the first year. if a 67 then its possibly a 390 or 428 unless its a late build that got a 429.
If its is a 429, it will fit the 400 bell if you use a diaphragm clutch and a internally balanced 429/460 flywheel I think. The 400 clutch and fly wheel will not work. Clutch pattern is different and the flywheel is the wrong balance. You will also need swap mounts and 460 truck manifolds or 429/460 swap headers, 460 4x4 truck pan/pickup/dipstick and possibly some different front accessory brackets.
Old Mar 23, 2017 | 08:23 PM
Anthony79's Avatar
Anthony79
Thanks for the info. I called the guy who owns the car and it turns out the engine is a 428 he said he must of hit the wrong button when he text me the info. Im a little bummed out. But I think that engine is just as good and will work out. thanks again
Old Mar 24, 2017 | 08:51 AM
kettle-one's Avatar
kettle-one
Nothing wrong with a 428, great engine. You'll need an FE bell housing and 76- back F-150 FE frame stanchions to make it fit your 79. I don't know if F-250 "High BOY" narrow frame stanchions will work as your 79 is wide frame. L&L might make what you need.
dgully
Feb 13, 2014 10:55 AM
trucksick
Engine Swaps
Aug 8, 2009 08:59 AM
roger dowty
Apr 19, 2009 10:56 AM
mositso
20
Jan 3, 2009 08:34 PM
woopud
Aug 31, 2004 01:08 AM
