Ways to install gooseneck hitch
Old 03-22-2017, 07:22 PM
Dutter 2's Avatar
Dutter 2
Dutter 2 is offline
so I have this style hitch that I found at the junk yard and was thinking of how to install it. I'd like to just slip in some thin rectangular tubing on the flat spot of my frame but it's supposed to be like 4 inches past the front axle. Any good write ups on this ? I do have a welder FYI that I know how to work.
Old 03-23-2017, 02:24 AM
raystankewitz's Avatar
raystankewitz
raystankewitz is offline
If you know the manufacturer of the receiver, you could find the installation manual for the unit. Typical install has a robust framework under the bed, bolted to the frame. The receiver then sandwiches the bed between it and the framework.
Old 03-23-2017, 12:05 PM
eakermeld's Avatar
eakermeld
eakermeld is offline
I had that hitch In my 94 and didn't like it. It seemed to be loose or flexing or something and jerked you back and forth in the seat even with an empty trailer on a smooth road. If you do use it, do what ray said and make a VERY robust framework for it to mount to.
Old 03-23-2017, 12:08 PM
subford's Avatar
subford
subford is offline
You need to go back to the salvage yard and get the side plats and the cross bars.
For your F150:
http://www.towingproducts.net/Applic...ions/N4437.pdf
For your F250:
http://www.catalograck.com/ImgVD/BUO/N4448.pdf
Old 03-23-2017, 12:48 PM
Dutter 2's Avatar
Dutter 2
Dutter 2 is offline
Oh no it was a very back yard hokey set up lol I'm better off making my own.
finnf250
2017+ Super Duty
41
03-13-2022 05:07 PM
snowdog79
Fifth Wheel & Gooseneck RV Towing
07-18-2016 01:14 PM
lakedweller
1999 to 2016 Super Duty
04-26-2011 01:49 PM
mongo75
07-17-2007 07:20 PM
huntercgr
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
05-22-2004 06:53 PM
Quick Reply: Ways to install gooseneck hitch
