Engine randomly cuts out
Old Mar 21, 2017 | 11:48 PM
Richard Templeton's Avatar
Richard Templeton
The engine in my truck sometimes cuts out seems to be at idle. takes a lot of cranking toget her going. might be related but the eletric fuel pump seems to run everytime i turn the key on and if i sit with key off and the engine not going i hear the pump come on again. no external leaks can be seen.
Thanks for any help there not alot of knowlodge of these trucks is hard to find here in new zealand
Old Mar 22, 2017 | 12:22 AM
UcaN's Avatar
UcaN
More than likely its your Cps sensor.......!!! Might as well change it if it hasnt been changed in a while. They are known to go bad.
You should have it scanned for fault codes.
Old Mar 22, 2017 | 12:50 AM
Richard Templeton
Thanks you wouldnt happen to have a part number?
Old Mar 22, 2017 | 12:56 AM
AllaboutMPG's Avatar
AllaboutMPG
Only use OEM for this and other electronic sensors on this motor. It really doesn't work well with aftermarket
Motorcraft Cam Position Sensor CPS 94-03
BBQJoe
23
Mar 25, 2019 02:43 PM
FordPowerStroke
Apr 23, 2014 09:14 PM
Highmark18
45
Sep 22, 2012 11:25 PM
mchild
Jul 21, 2008 09:33 AM
03_PSD
20
Jun 3, 2008 07:02 AM
