87 F150 Crank & fire no-start mystery
Hi everybody,
I was working with my friend on his 87 F150, and we can't get it to start. Here is the situation . . .
1987 F150 2wd
Straight 6, Fuel Injected
Cranks, but won't start.
It will start and run smoothly when you spray starting fluid into the intake.
We replaced the EEC relay (it looked corroded) and the Fuel pump relay
Both the high pressure pump and low pressure fuel pumps are working (we removed the front tank to make sure the low pressure pump was working because we could not hear it . . . turns out it was.
Fuel pressure test reads 50psi with the key on
Fuel filter is not clogged
I don't want to jump to the conclusion that we need to buy a $100 computer for this truck . . . it was running just fine a few weeks ago.
Any helpful suggestions as to what to check next (or how to check if the ECU is any good) would be greatly appreciated.
Thank you!
Joe
1987 F150 2wd
Thank you!
Joe
EDIT: Next thing to check would be if you are getting injector pulse or not
Hi guys,
thank you all for the replies.
yardbird - thanks for the link. It has given us some more to work on.
Tedster - I am not sure what you are referring to when you mention e-caps on the board . . . could you help me understand that better?
Joey2fords - We hooked it up to the OBD 1 code reader, and it said that it could not read the ECU.
Thank you all!
Thank you all!
Electrolytic capacitors. Modern cars and trucks have a passle of the critters on electronic control units and other components. A soldering iron, some 60/40 rosin core solder, and a few replacement caps and the board will be good to go.
Not saying this is your problem necessarily, but the capacitors that are on the board were made in 1987, if the board IS the culprit, then this is a pretty easy repair. A junkyard board would likely have the same age on it. Just throwing that out here.
christofalex
07-30-2016 08:58 PM
xrsfsho
36
12-24-2014 09:37 PM
Mount Nemo
09-13-2003 01:16 PM
