Shift Linkage?
Old Mar 21, 2017 | 03:32 PM
31tudor's Avatar
31tudor
Shift Linkage?
Hey fellas, I've been battling with my shift linkage for a little while and I'm looking for suggestions. The truck is a '79 F150 with a 351 and a C6 with column shift.
I've had the truck for a few months and the linkage was sloppy when I got it, but it "worked" mostly. About a week ago the truck suddenly had no first or reverse gears. Playing with the adjustment at the trans proved the transmission was okay, and adjusting it got the truck up and going again.
Right now the issue I'm having (other than all of the play in the linkage) is that there's no positive engagement from the column shifter between gear selections, although I have it adjusted where I can all gears except 1st.
Are there particular "wear parts" that I should look to replace? Is this a common problem? The linkage is factory and has about four different rods and four joints to make it work.
Thanks for the help!
Old May 10, 2017 | 11:23 AM
31tudor's Avatar
31tudor
Never mind, sold the truck.
Old May 10, 2017 | 07:12 PM
1976F350campspecial's Avatar
1976F350campspecial
that will work
Old May 11, 2017 | 08:51 AM
HoustonDave's Avatar
HoustonDave
well, we'll wait for the new owner to post....
CalebJns
Apr 30, 2010 01:27 PM
shawnyboy
May 20, 2009 10:54 PM
