Power Window Reprogram?
Old Mar 20, 2017 | 08:26 PM
Blondie70's Avatar
Blondie70
Can the dealer reprogram my power windows with auto up and down to work only when the button is pushed or pulled up ?
I do not like the full auto up and down mode.
I am having some problems with it also...today the driver's side got confused and would not respond at all. After multiple tries, it finally started working.
I guess I will have to bring it in if it acts up again, and want to be prepared to get it changed over if that will work.
Thanks for any help.
Pete
Old Mar 21, 2017 | 06:37 AM
2jhanna's Avatar
2jhanna
My window buttons have a "mid" position and a "full" up/down position ( you feel a slight detent or click at the full position).
If you just slightly press/pull to the mid position, you can put the window where you want it.
Old Mar 21, 2017 | 07:49 PM
Blondie70's Avatar
Blondie70
Thanks, will try. Wonder if they can reprogram as mentioned ??
Old Mar 22, 2017 | 04:06 AM
brokenleg's Avatar
brokenleg
jhanna is right. the switch has detents... why reprogram when you can already do it? mine will stop....or auto go down.
Old Mar 22, 2017 | 07:31 AM
ubereal2's Avatar
ubereal2
That took some getting used to for me too, well and I'd imagine a lot of people. I still push that button too far if I just want to crack the window a bit.
Unk Bob
Old Mar 22, 2017 | 07:38 AM
paintballdude05's Avatar
paintballdude05
It's possible to reprogram them on the '15+ trucks, I'm not sure on the older ones. If anything, it would probably only be available to the 11-14 trucks as they had a BCM vs. the earlier trucks with the GEM module. Forscan is what you'd use to do it yourself if it was possible.
Old Mar 25, 2017 | 08:40 PM
Blondie70's Avatar
Blondie70
I tried the light touch on mine and it works....but it is VERY sensitive...no noticeable notch or bump... it works tho....I did not realize it had this feature....thank you gents for the info....will keep it as it is.
Old Mar 25, 2017 | 08:52 PM
2jhanna's Avatar
2jhanna
It took me a few days and few tries to get the right touch
Old Mar 27, 2017 | 11:12 AM
rbentnail's Avatar
rbentnail
I wanted to completely, permanently disable the bounce back feature. You know, the part that thinks there is an obstruction and automatically runs the window back down. There's a section in the owner's manual but it worked only until the next time the truck was turned off. Any ideas? 2013 STX.
Old Mar 27, 2017 | 03:42 PM
2jhanna's Avatar
2jhanna
Isn't this a safety feature? And I can't think of a situation where this feature would be used where it's not safety related.
Why would you want to disable it, and would use do you have where this feature becomes a problem?
Old Mar 28, 2017 | 12:33 PM
rbentnail's Avatar
rbentnail
Yeah, probably a safety feature for most people but my situation is different so I'd like to have choices. I have no kids. My wife rode in my truck exactly 3 times last year. Exactly 3. And at 55 yrs old I would expect she'd know by now not to put her fingers in a window that's going up. The only other person that's been in my truck is also 55-ish and probably knows better by now as well. I don't need to bounce back feature and it's a giant PITA with my window visors. So again, I'd like the choice of adjusting the sensitivity of it. I'd like the choice of whether I could permanently disable it or not. My household doesn't subscribe to the notion of a nanny state that has to protect me from every thing every day. Choices, if only I had choices.......
Jeff heine
Dec 18, 2016 04:42 PM
AC75
Apr 2, 2009 01:51 PM
Thumper47
1983 - 2012 Ranger & B-Series
13
Oct 5, 2003 04:17 PM
