King pin thrust bearing
Old Mar 19, 2017 | 07:22 PM
john jamieson's Avatar
john jamieson
Installing new king pins in my '66. Is there a way to effectively pack the bearing with grease before intalling them, like you would with wheel bearings?
Thanks.
john
Old Mar 19, 2017 | 07:34 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Thanks.
john
There will be a hole for a Zerk (grease) fitting in the spindle used for this purpose.
In 1963, Ford introduced "Lifetime Lubrication" put rubber plugs in the zerk fitting threaded holes located in the spindles, tie rods, draglink and etc.
87907-S8 .. Spindle Zerk Fitting: 1/4 -28 straight. Available from any auto parts store.
Old Nov 24, 2017 | 05:42 PM
kv66f100's Avatar
kv66f100
My 1966 Ford truck factory service manual says to pack the bearings with chassis grease before installation (or reinstallation). I tried using my trusty K-D bearing packer, and also "hand" packing with the palm of my hand but neither method seemed to get much grease into the bearing. The bearings are pretty well enclosed in the metal shells. I hope Bill is right and that grease from the Zerk fitting on the bottom will promote lubrication!
Old Nov 25, 2017 | 07:27 PM
mrpotatohead's Avatar
mrpotatohead
I'd definitely try and hand pack them. This will be the only opportunity to really get the grease in there. The zerk will only allow greasing up to the point that grease leaks out of the path of least resistance. Greasing kingpins should be done both with the wheel hanging free and then with weight on it while turning the spindle left and right. You will leak a lot of grease out but this is what it takes since there are no seals.
Old Nov 28, 2017 | 07:10 AM
kv66f100's Avatar
kv66f100
Thanks for the tip! I'll try hand packing again before reassembly, and enlist a helper when hitting the grease fittings with the grease gun.
RV_Tech
All Things Towing
41
Dec 26, 2015 10:16 AM
obscurity
May 31, 2013 01:36 PM
PW_SD
Oct 2, 2009 01:10 AM
ksmith203
Mar 26, 2007 09:03 PM
hllon4whls
Feb 10, 2006 11:07 PM
