Headlight switch plug with fuses
Old Mar 19, 2017 | 03:31 PM
denny7170's Avatar
denny7170
1963 F100 2wd 223 strait 6. My tail lights went out completely, brake lights and all. I reached under the dash and moved the headlight switch around a little and they came back on. I cahnged the headligjt switch, Later it blew a fuse in the same spot. I changed the fuse and it happened again but did not blow the fuse. Is that plug available anywhere in case it is shorting out?
Old Mar 19, 2017 | 03:59 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1964 pic from 1964/72 truck catalog, 1961/63 parts are essentially the same.
Old Mar 19, 2017 | 05:14 PM
denny7170's Avatar
denny7170
Thank you very much.
larryb346
Aug 29, 2009 01:32 AM
66f14evr
Electrical Systems/Wiring
Nov 4, 2005 01:50 PM
topohill
Jan 5, 2005 09:28 AM
liljase
Dec 5, 2004 03:33 PM
Chevythunder7578
Aug 1, 2004 08:27 PM
