Sponsored by: Real Truck
tpms sensors
Old Mar 19, 2017 | 10:31 AM
SnowPlowDriver's Avatar
SnowPlowDriver
tpms sensors
I am looking for an extra set of steel wheels and most do not have sensors. What is required to make the system work? Are they all the same frequency? How about the sets on ebay for about $60 a set?
Old Mar 19, 2017 | 12:03 PM
alloro's Avatar
alloro
TPMS sensors come in two frequencies, 315MHz and 433MHz and as a rule the two are not interchangeable. You didn't specify the vehicle but I'm pretty sure you'll be using the 315MHZ ones. As for the eBay sensors, if they're Ford OEM get them, if they are a generic shipped from China brand then do not, most of those fail.
Your second issue will be programming the sensors into the vehicle every time you swap tires. Again without knowing the vehicle I can't know the relearn procedure in order to give correct advice.
Old Mar 19, 2017 | 12:23 PM
SnowPlowDriver
Both the f250 and f350 are 315 mhz. Is the programming DIY with the proper tool?
50stangpower
Sep 17, 2018 03:59 PM
99 f150
6.7L Power Stroke Diesel
Aug 27, 2016 11:18 AM
theoldwizard
May 13, 2016 02:12 PM
D2Gags6.0
Jul 27, 2008 12:20 PM
Moyerboy
1997 - 2003 F150
Jun 16, 2007 07:55 PM
