What is the Hot Set Up to improving head lights...
Old 03-18-2017, 06:59 PM
Metal twister's Avatar
Metal twister
Metal twister is offline
So I did the leveling kit thing and went to 35's and now I'm needing to re adjust my headlights. Maybe it's just me but they really suck compared to all my other vehicles.
So what is the answer... HID bulbs, New non fogged lens, after market projection lens.... What are you guys using that works well. I'm sure an adjustment will help but I have never been impresses with the lighting. I'm thinking change them out then adjust. Ideas? Mine is an 01 so how new can I go and still have them fit?
Old 03-18-2017, 07:08 PM
SRBF150's Avatar
SRBF150
SRBF150 is offline
The best would be a projector retrofit. Next is 04 housings, a couple relay's and Hella 100W bulbs. I went the hella route and dropped in a LED bar that is triggered by High beams. It's like our Lord and savior is showing me the way now.
Old 03-18-2017, 09:38 PM
Whitey Ford's Avatar
Whitey Ford
Whitey Ford is offline
FTE-Spread The Knowledge
05 headlight assembly w/ HID projectors and LED halos.
Old 03-19-2017, 12:36 AM
P4IN COMM4NDO's Avatar
P4IN COMM4NDO
P4IN COMM4NDO is offline
I have a 50 inch on the roof and a 13 inch on the bumper. Gets the job done. I'll eventually venture into aftermarket headlight assemblies, but now I don't have to worry about having high beams out
Old 03-19-2017, 01:50 AM
Shovelheadrob's Avatar
Shovelheadrob
Shovelheadrob is offline
I tried better bulbs, I tried replacement lights, I tried replacement lights with higher watt bulbs & relays but each was only a slight improvement over the old cloudy original lights. I now have 05-07 style with retrofit projectors, the difference is night & day, you see what I did there!
Old 03-19-2017, 10:27 AM
Metal twister
Light bars are wonderful but ya don't want to get caught with them on on the street in So Calif. they are great for off road though. I just drilled some holes in my bumper with the thought of mounting hid's behind them. Thought it less conspicuous than the bars but still helps a great deal. But even with those I need to do something with the head lights. I'm sure liking what I've seen here so far.
Old 03-19-2017, 10:32 AM
Metal twister
Each hole gets one of these. Front facing gets a spot and sides gets floods... That's the plans anyway. I have a spare bumper if it doesn't work out as planned.
Old 03-19-2017, 01:37 PM
P4IN COMM4NDO
Interested to see how that goes
Old 03-19-2017, 02:10 PM
Metal twister
Yeah... LOL
The problem is the time to get it done. I had to drill the holes to make it embarrassing to myself so I wouldn't put it off forever. I have fab'ed up the mounts for them now I need to weld them in place. I installed the switch on the shifter so I am moving forward slowly...
Old 03-19-2017, 05:07 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Links to the bulbs and relays you used, please!
Stewart
Old 03-19-2017, 05:48 PM
SRBF150's Avatar
SRBF150
SRBF150 is offline
Old 03-19-2017, 09:05 PM
Stewart_H's Avatar
Stewart_H
Thanks for the links.
When it comes to electricity, wiring, and anything amp, volt, resistance, ohms, related, I have zero intelligence regarding that field, so can you please explain why a relay harness is needed and what it does? Thanks!
Stewart
Old 03-19-2017, 09:25 PM
Sous's Avatar
Sous
Sous is offline
Received 4,464 Likes on 2,853 Posts
Like SRBF150 I upgraded my headlight housings, bulbs and harness.
Bulbs:
Amazon Amazon
Headlight Housing:
Amazon Amazon
Harness:
Very similar to the link SRBF150 provided, but from Ebay.
The housings cleared things up very nicely. The bulbs are much brighter and the beam seems to be more focused, not like a projector but definitely noticeable. The harness provides clean and ample power to the headlight bulbs directly from the battery. The gauge of the harness wire is much thicker than what the OEM wiring is. I was having a small amount of light flutter/flicker when sitting at a traffic light, but the upgraded harness cleared that up.
Old 03-19-2017, 10:08 PM
SRBF150's Avatar
SRBF150
SRBF150 is offline
Yep, as Sous indicated, the purpose for the relay harness is to increase amperage capacity to the higher watt bulbs. A benefit of this is also that the load is removed from all the factory wiring and isolated to the harness which is much shorter and heavier gauge so, it will usually provide an increase in voltage. The harness will use the factory wiring to trigger the relays for low/high beam.
Old 03-28-2017, 12:37 PM
Metal twister
Just thought I would put the link up to the bumper light thread... No need to duplicate a thread.
https://www.ford-trucks.com/forums/1...l#post17069642
Quick Reply: What is the Hot Set Up to improving head lights...
