Tuning question
Old Mar 18, 2017 | 02:43 PM
BBslider001's Avatar
BBslider001
Tuning question
Hey all, I am usually on the OBS side, but looking at 99-00 Superduties. My question is what do you guys do for tuning? TS Chips or Hydras or something I have never heard of? Thanks.
Old Mar 18, 2017 | 02:45 PM
Rikster-7700's Avatar
Rikster-7700
A lot of guys like the Hydras here lately, and a lot seem to like Gear Head tunes running on them
Old Mar 18, 2017 | 04:19 PM
BBslider001
Thanks! The same Hydra we use on the OBS, correct?
Old Mar 18, 2017 | 04:28 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
As Rikster said, Hydra with GearHead tunes and could not be happier with them. Daily driving, heavy towing, high idle, no start, stock and regular tow is all I have and need.
Not sure if it is the same Hydra as the OBS, but you could probably find out just by going to the PHP or GH sites.
Old Mar 18, 2017 | 04:29 PM
BBslider001
Sounds good. I'd go with GH myself. I always hear good things for tuning the 7.3 by them.
Old Mar 18, 2017 | 09:26 PM
jhl3's Avatar
jhl3
PHP Hydra with Gearhead (GH) tunes written by Matt. Non-proprietary, if you don't like Matt's tunes then there are at least 10 others who are writing tunes for the Hydra. Gearhead/Matt offers free updates to the tunes as you upgrade your truck: injectors, turbo, transmission, etc. regardless of where you buy those upgraded parts.
Many of us who are currently running the Hydra have tried most of the other platforms, I have run 4, and this is where we finally landed after spending a ton of money on the other non-Hydra stuff.
GH offers the least amount of smoke, lowest EGT's, best transmission shifts, smoothest/most linear powerband based upon throttle input I have experienced. ICP remains high due to keeping FIPW in check.
The truck in my sig is a work truck and tows to its' max rated weight.
Old Mar 19, 2017 | 04:49 PM
Toreador_Diesel's Avatar
Toreador_Diesel
Vote for Gearhead and the Hydra.
I came from the Lost Sheep of DP-Tuner camp and now I run Matt's tunes on both my trucks. Better fuel economy, better power, smoother running, better shifting, not to mention better customer service.
Matt personally tuned both of my trucks and I can't complain, there are many out there who write tunes for these trucks, but none like Matt.
Old Mar 19, 2017 | 06:43 PM
BBslider001
I looked on GH website and it only mentions single shots. Aren't all 99-03 split shots? I'll be looking at Hydra and Matt for sure.
Old Mar 19, 2017 | 08:35 PM
Toreador_Diesel
The write for the split shots too.
Old Mar 19, 2017 | 08:54 PM
BBslider001
Thanks bud.
Old Mar 22, 2017 | 12:34 AM
BBslider001
Originally Posted by comsupany
I'm interested in answers to this as well. Also can someone tell me what kind of mileage improvements they have experienced?
Or you guys could start a new thread with your questions...
Old Mar 22, 2017 | 12:47 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I can also chime in for GREAT results from Matt at Gear Head. I had canned tunes (Diablo) before (I did like them for what they are), and these GH tunes are much smoother and crisp. EGTs are better managed. Service was excellent, as was their timeliness and KNOWLEDGE of what I was needing and what they provide.
Old Mar 22, 2017 | 08:33 AM
nossliw's Avatar
nossliw
Hey bud, I'll second gearhead. We use them from stock to large hybrids in all different applications. The reason I suggest them is they are the only tuner that has listened over the years to focus on heat and high altitude challenges vs smoke and big HP numbers. Taking a 500 hp truck and cutting it back to reliably haul a 15-17,000lb 5er over eisenhower or cottonwood pass took a bit of testing, but they were the only ones that even came close with a TS style chip.
Old Mar 22, 2017 | 10:55 AM
BBslider001
Thanks Nick! I am going to give them a shot for sure. I keep hearing good things and nothing bad. I gotta find my new truck first!! LOL It does seem they listen white a bit and operate based on that. I like it. I'll report back when it all comes together.
Old Mar 22, 2017 | 06:59 PM
Stewart_H's Avatar
Stewart_H
Their questions were definitely going in a bit of a different direction than what you were inquiring about, so I cut the posts and started a new thread for them.
Stewart
