Fox Body header issues
Old Mar 18, 2017 | 01:51 PM
eric8's Avatar
eric8
Well I am bound and determined to get these things to fit on my truck. After reading several threads where people used these with success, I am having issues, I guess mainly because my truck is a manual transmission. After buying a mini starter to get the needed clearance on the passenger side, it looks like the collector outlet on the driver's side is going to be dumping out right in front of my "Z bar" for the clutch linkage. Any options available to get rid of all of this mechanical linkage? Hydraulic conversion kits available for our trucks? This is on a 1976 F100 2wd, 302, 3 speed manual.
Old Mar 18, 2017 | 05:17 PM
boingk's Avatar
boingk
Definitely hydraulic options - down here in Australia we imported F-series trucks and converted them to LHD, which meant all the controls on the opposite side... so we used a hydraulic clutch to keep things simple.
For under $100 all up you should be able to get it sorted.
Master cylinder:
New Genuine *PROTEX* Clutch Master Cylinder For FORD F100 351 CLEVELAND V8 CARBâ | eBay
Slave cylinder:
FORD FALCON Clutch slave cylinder XR XT XW XY XA XB XC XD F100 6 cyl & V8 | eBay
Hydraulic line (bend it yourself):
1x TRAILER BUNDY TUBE HYDRAULIC BRAKE LINE AND NUTS 1.5M. DOUBLE FLARED | eBay
Hope that helps, it'll at least give you a starting point.
- boingk
Old Mar 18, 2017 | 06:57 PM
eric8's Avatar
eric8
Wow boingk, I didn't know those options were available. So that slave cylinder bolts right up to the factory 3 speed? I'm sure the master cylinder and linkage would require quite a bit of fabrication, right?
THE71BEAST
Sep 15, 2016 08:21 AM
cheddar89
Feb 6, 2012 09:04 AM
Mustng19
Aug 28, 2010 06:50 AM
black66
Mar 22, 2004 12:21 AM
200000+F150
Mar 23, 2003 03:07 PM
