F350 DRW Airbags?
F350 DRW Airbags?
I upgraded from my '14 6.2 F250 CCSB to a 2011 F350 DRW 6.7 . Pin weight max is 2700lbs assuming empty garage. I haven't pulled with it yet, but I'm wondering if I should even bother with airbags on this truck. I had the firestone remote system with airlift 5000 ultimate bags on my F-250 and wasn't impressed. It seemed like I constantly had to run the bags at 80-100PSI to stop the truck from porpoising.
With the longer wheelbase and significantly heavier spring package, are you guys running bags for pinweights less than 3000lbs? I'd like to invest that money in a trailair pinbox for my trailer instead.
I have the Firestone airbags on my dually but my pin weight is a lot higher than yours. The bags should fit the dually with the exception of the left upper mount and those you can order through SDTRUCKSPRINGS.com for around $60 IIRC as it's been a few years. So I would keep the bags for possible installation later on if needed. As for the TrailAir, it made a huge difference in the bouncing and harshness of my rig. I would get the standard TrailAir and not the TrailAir Flex as it can cause a bit of chucking with some rigs. Some people do haul my same pin weight without bags, but I like to keep mine level.
I saw Airlift released a 7500 XL bag this year. Could have used that on the F-250.
It's prolly too late but it has been my experience with air bags that the porpoising is from the factory shocks not being able to dampen the truck springs and air shocks when combined.
when I crank up my ranchos from 5 to 7-9 all ov the porpoising goes away with fver and the bags set at 30 lbs.
I have bags on my 13 DRW also. My old gooseneck trailer had a pin around 2300 empty, but loaded figure 2500. The truck was sitting nose up and rode like hell. Airbags solved the ride issues and corrected the ride height. I do not have the snow plow prep or FX4 packages. Still have stock shocks. With the old trailer I also got a driveline vibration if I stood on it with no bags. They resolved that also putting the driveline angle back where it belonged. New trailer is only a claimed pin weight of about 1600 and has almost no storage forward of the axles. Only takes about 25-30 pounds to smooth the ride a bit and bring the height back up.
I have airlift 5000 ultimate bags and the wireless air control system. Happy with both so far. I am looking into replacing the airlift lower bad mounts with Firestone parts after seeing a thread where the bumpstop tab broke off.....................
I have snow plow, camper and Fx4. Wonder if that is why I don't need anything. I just barely touch the upper overloads with my 5er.
