GPR / AIH relays
GPR / AIH relays
Alight fellas, my gpr led didnt light up this morning. So i'm guessing my gpr is bad. I'm letting "cool down" right now, to see if the light appears again, or voltmeter it..etc. IF it is dead/bad, i want to use the AIH relay for in its place, since mines gutted. Any of you know what wires go to what post? The relay for the AIH is actually "taller" than that of the GPR. Not to worried about that, since i've read that i can use this relay in the GPR location.
on
This should help you out.
GPR and AIH Relay Wiring.pdf
Both relays share the same power supply and ignition feed. The only differences are the outputs to the glow plug wiring/air intake heater and the wires that control the relay grounds from the PCM.
Thanks Ken. I just went out and volt tested the "legs". The wire that has the covers on each are hot with key off. The other big legs get energized along with the little ones, when key is turned, however NOT the leg that is for the G.P. Either the truck is still up to temp for it not to kick on or the relay is bad. I'll check it in the morning....
Attachment 42900
Attachment 42900
blue66tang95f150
09-19-2017 03:28 PM
tylerc82588
06-26-2013 12:36 PM
