Muffler system question
Old Mar 16, 2017 | 03:34 PM
Estam's Avatar
Estam
2000 Ex V10 - Took the Ex in to Muffler shop due to loud muffler and found the Flange assy. in front of the cat apart with no hardware to hold it together. The tech suggested cutting of the flanges and welding in a pipe.
Checking with Autozone they supply a gasket (walker 31638) but they have no info on the hardware that holds it together.
Can anyone suggest here what to do either have the tech weld in a pipe or get whatever hardware needed and fit the gasket with the correct hardware.
Does anyone know what the hardware looks like, are they just hi-tens nuts and bolts?
Many thanks for any suggestions,
Old Mar 16, 2017 | 05:31 PM
pirate4x4_camo's Avatar
pirate4x4_camo
A pic of what is left of your would be helpful.
Old Mar 17, 2017 | 09:18 AM
Snowseeker's Avatar
Snowseeker
If the flanges are in good shape yet just get the gasket and bolts and put it together.
If the flanges are in rough shape cut them out and weld in a pipe.
Old Mar 17, 2017 | 03:24 PM
WE3ZS's Avatar
WE3ZS
I don't think that the hardware is anything special, just some pressed in bolts/studs and nuts on the other side. I would just get the new gasket and replace with decent nuts and bolts with a lock washer.
Mine is an '05 so it may be a little different than your '00, but here are what mine looked like.
My cat side flange just before I cut it off.
The factory joint, you can see the flat round heads of the pressed in bolt/ studs.
Old Mar 18, 2017 | 08:25 AM
Snowseeker's Avatar
Snowseeker
Grade 8 bolts are good for these type flanges.
Old Mar 18, 2017 | 10:53 AM
Apocalypse's Avatar
Apocalypse
This. Just grab a set and toss them in
Old Mar 19, 2017 | 10:55 AM
Estam's Avatar
Estam
Gasket from AZ and the tech bolted the flanges. There was just an issue that he thought the bolts would be difficult to get out and burning and replacing with a pipe would be easier. I wasn't comfortable with that hence the question. Many thanks, sounds like a Cadillac now : -)
Old Mar 19, 2017 | 11:32 AM
WE3ZS's Avatar
WE3ZS
Glad to hear you got it all sorted out. But if the hardware wasn't there how did the tech think it would be difficult to get the bolts out? .
Old Mar 20, 2017 | 08:13 PM
Estam's Avatar
Estam
Yes I thought the same thing to myself, I didn't see it but
I think he thought there were bolts/studs broken off and
he had to drill them out which, as you know can be a real
beach ; -) For these hardened muffler guys cutting and
welding a pipe in is a breeze.
Powerstroke2004.5
Jul 24, 2019 03:38 PM
rangergolfer
1983 - 2012 Ranger & B-Series
Dec 6, 2010 11:15 AM
OZX1
Jul 13, 2008 09:29 AM
RhinoScores
Sep 13, 2006 06:45 AM
tealboy1
Apr 28, 2002 03:49 AM
