´56 ...not a "build thread" more a "modification thread"...
  #76
Old 07-14-2017, 02:34 PM
ingo's Avatar
ingo
ingo is offline
...did the final welding on the oilpan - baffles and the lengthened oil pickup:
  #77
Old 07-14-2017, 02:50 PM
ingo's Avatar
ingo
ingo is offline
I did not like the "U-Bolt mounts" which came with the swaybar kit for the rearend :
so i built my own:
i better decided to do that before i painted the rearend
...and the rest of the rear swaybar mounting:
sorry, i have no idea why the forum turned my pics !!??
  #78
Old 07-14-2017, 03:19 PM
fordslut's Avatar
fordslut
fordslut is offline
you got a great rear.
  #79
Old 07-14-2017, 09:20 PM
mustangmike6996's Avatar
mustangmike6996
mustangmike6996 is offline
Looks great! Nice work!
  #80
Old 08-12-2017, 06:22 PM
ingo's Avatar
ingo
ingo is offline
painted the built oilpan...
  #81
Old 08-13-2017, 08:16 AM
ingo's Avatar
ingo
ingo is offline
...brought the bed and the rear fenders to the paintshop. I didn´t expect the bed is that crunchy and wavy / dented and has a lot of holes which were just bondo filled:
i guess i will buy a new one from the early ford store.
That is how the fenders look... rusty but not that bad
we will restore the fenders and paint 'em.
  #82
Old 08-13-2017, 02:00 PM
rico56's Avatar
rico56
rico56 is offline
Hi Ingo,
sand blasting reveals even the things you don't wanna see . The bed doesn't look worth restoring but I think the fenders are worth a try.
Keep going mate!
The following users liked this post:
  #83
Old 08-13-2017, 02:26 PM
fordslut's Avatar
fordslut
fordslut is offline
what a drag, you spent time installing those nice tubs. things have away of snowballing though. I didn't plan on installing a rear 4 link till I found I couldn't stop looking at yours.
  #84
Old 08-13-2017, 04:03 PM
ingo's Avatar
ingo
ingo is offline
...haha thank you i´m glad you like it and i hope it will ride as good as i looks
  #85
Old 08-13-2017, 04:06 PM
ingo's Avatar
ingo
ingo is offline
Originally Posted by rico56
Hi Ingo,
Keep going mate!
...I will pick up a new bed in three weeks at the early ford store in Ohio.
It´s just a bummer about the tubs i installed, but no big deal
  #86
Old 08-13-2017, 04:38 PM
fordslut's Avatar
fordslut
fordslut is offline
cut out those tubs and leave a 5/8" to 3/4" (or whatever you guys call it) lip around the arch, and epoxy it in, or spotweld / rosette welt it. i think if you go on dan carpenter's website you'll find thats how they do it. projects looking great, it helps me to get moving on mine.
  #87
Old 08-13-2017, 04:43 PM
ingo's Avatar
ingo
ingo is offline
we call it millimeter here.
thanks for the idea but that were my first selfmade tubs, not bad but i´ll try better ones... one fender to cut is not a big investment.
  #88
Old 10-14-2017, 07:34 PM
fordslut's Avatar
fordslut
fordslut is offline
are you still alive? or did your truck get you.
  #89
Old 10-17-2017, 02:11 AM
ingo's Avatar
ingo
ingo is offline
Haha, yes i´m alive and healthy :-) Don´t worry.
There were some other things to do in the meantime and yes maybe i had a little "motivational problem"
As i mentioned i bought a new bed from midwest ford, which lies on the bed of my Cabover, i´m shipping from Cincinnati. I expect it next month to be here.
In the meantime i started working on the 3rd Member. I bought an Eaton True Trac a while ago, which was designated for my ESSEX Rat Rod to exchange it for the spool in the Rod.
I wanted a 31 Spline in the Truck also so i decided to use the True Trac for my Truck and leave the Spool in the Rod, which is good for dragracing.
I´m thinking about the Ratio, i have a brandnew 3.50 Ring & Pinion Set, which i´m going to use, but maybe later i try the 2.75 which came with the Lincoln Versailles rearend....
we will see.
  #90
Old 10-17-2017, 03:01 AM
fordslut's Avatar
fordslut
fordslut is offline
is the coe here in the u.s.? nice looking truck. I had hoped my new bed would be all primed by now, other stuff keeps butting in front of the line. I did a 4 link after seeing how nice yours is.
Quick Reply: ´56 ...not a "build thread" more a "modification thread"...
