12volt constant install?
Old Mar 15, 2017 | 02:59 PM
Dieselman1987's Avatar
Dieselman1987
I just got rid of my 2013. Love the fact that it had a 12 volt under the back passenger seat. I would let thing's charge or power my led light bar.
So can anyone tell me or let know if they've out in they're own 12 v power plugs with constant power.
Old Mar 15, 2017 | 05:22 PM
Robeleo's Avatar
Robeleo
As far I know non of the almost 10 power sources, jk, have constant power unless it's on, I'm working to make one or maybe two always hot using upfitter switch including the 12V for trailer
I'll try to make some kind of tutorial or a list take pictures and pass the information of how to
Old Mar 15, 2017 | 05:56 PM
Dieselman1987
Thanks pal.
I was thinking of running a whole new power distribution panel from the battery to inside the cab with separate fuses for each. Just so I can power up anything I want without needed the truck on. All low draw items.
Old Mar 15, 2017 | 06:53 PM
railrode1's Avatar
railrode1
I tapped from the power inverter under the rear seat. It's on a 60 amp fuse, so any tap would need fused smaller.
Old Mar 15, 2017 | 07:07 PM
Dieselman1987
Does the truck need to be on or is that constant?
Old Mar 15, 2017 | 07:42 PM
railrode1's Avatar
railrode1
It is constant. The inverter turns on via a trigger wire once engine is started. They are the two biggest wires.
Old Mar 15, 2017 | 08:46 PM
Dieselman1987
Great to know. Any pictures of your setup?
Old Mar 15, 2017 | 09:50 PM
Snowtower 2's Avatar
Snowtower 2
Subscribed!
Old Mar 15, 2017 | 10:35 PM
Snakedriver's Avatar
Snakedriver
This could be a really good thread.
Old Mar 16, 2017 | 07:29 AM
charlesweaver3's Avatar
charlesweaver3
Looking forward to pictures.
Old Mar 16, 2017 | 03:37 PM
railrode1's Avatar
railrode1
I don't currently but when I get back home to the truck, I'll see if I can snap some.
Old Mar 16, 2017 | 08:12 PM
2BSDowner's Avatar
2BSDowner
I am interested.
Old Mar 16, 2017 | 09:32 PM
mhoefer's Avatar
mhoefer
My last truck I ran a 10 gauge wire to the under back seat that was constant hot for running the headrest DVD. In this truck, eventually I will do the same under the back seat, dual plug, can plug in the DVD and run while driving or watch DVDs in the truck without the ACC on to keep input running. Just have to be careful type you leave enough battery for starting.
Old Mar 18, 2017 | 10:11 AM
Navydocsuperduty's Avatar
Navydocsuperduty
This is a screen shot from the Q256 bulletin, it shows a battery hot output circuit. May be worth looking into.
Old Mar 18, 2017 | 02:19 PM
railrode1's Avatar
railrode1
I can't get a clear picture but On the inverter, the plug near the center, the largest wires looks to be 10awg. It's the red one and black w/yellow stripe. All the other wires are noticably smaller.
