12volt constant install?
Old Mar 23, 2017 | 04:24 PM
Dieselman1987's Avatar
Dieselman1987
Originally Posted by Dieselman1987
I just got rid of my 2013. Love the fact that it had a 12 volt under the back passenger seat. I would let thing's charge or power my led light bar.
So can anyone tell me or let know if they've out in they're own 12 v power plugs with constant power.
Just wanted to see if anyone has made any ground here?
Old Mar 24, 2017 | 07:03 AM
Rasalas's Avatar
Rasalas
Originally Posted by Robeleo
As far I know non of the almost 10 power sources, jk, have constant power unless it's on, I'm working to make one or maybe two always hot using upfitter switch including the 12V for trailer
I'll try to make some kind of tutorial or a list take pictures and pass the information of how to
Similar to a trailer requiring 12V constant our slide in camper also requires a 12V constant 40 amp circuit. The factory available plug for the Lance has an 8 gauge wire and recommends wiring direct to the battery. I went off the guide and used the #6 upfitter switch which is sized accordingly through a relay in the distribution box. The distribution box for the upfitters has a two position jumper which regulates all switches to either always hot or key controlled. It would be nice if there were a choice for each switch. I guess with them always hot (as I have selected) operation of the vehicle is somewhat like a Dreamliner. Flipping switches and checking gauges before takeoff and landing.
Through Forscan you can extend the timeout duration of the 12v cabin accessory plugs. One of my next mods.
Now as I look around for a location for the onboard air gauge and finding nowhere to put it, maybe Ford will incorporate and upfitter gauge panel...just a thought. Would hate to be low on air when that damn Subaru plugs itself into the safety zone between my front bumper and the rear of the next vehicle.
FireZingr
2009 - 2014 F150
Apr 8, 2017 08:30 AM
96ford250
Apr 29, 2013 06:22 AM
blowhole
Mar 10, 2013 12:13 PM
WARRENNC
Oct 29, 2012 01:12 PM
Flatlanded87
Oct 14, 2006 05:39 PM
