Water Bladder tansfer setup
Old Mar 13, 2017 | 07:14 PM
scraprat's Avatar
scraprat
Top Answer: 5
For any new campers out there.
We boondock more now than stay at rv parks so getting water into the fresh tank was becoming a pain. I was just using 3 - 6 gallon water containers but at roughly 48# lifting and wresting with the funnel/ containers I finally broke down and put this together. Variation from others that I have seen on the internet. I was pumping from the containers but ordered the bladder to save on space.
I used a Seaflo 33 series 12v pump , 3.3 gpm
Amazon Amazon
I wired a trailer plug onto it and plug it under the tailgate .
I chose this pump for the time the one in the 5th wheel fails and I'll just use this one for it's replacement.
AquaTank II 30 gallon Bladder. That gives a 100 gallons for the 2 weeks and usually it's time to move on to the next location anyways.
Amazon Amazon
2_5/8" OD x 1/2" ID Vinyl hoses, #4 clamps 1/4"-5/8" diameter, 1_3/4"female hose end x 1/2" ID hose barb
The bladder sits in front of the hitch and doesn't hit the tailgate, so a perfect fit.
This is full @ 30 gallons
Just about empty
When completed with the water transfer the bladder can be folded up and the pump broken down taking hardly any space.
Old Mar 13, 2017 | 07:36 PM
RV_Tech's Avatar
RV_Tech
I like it. We do something similar with a blue boy tank to dump our gray water when we do not have full hook-ups. Pump out of our gray water tank to blue boy and then take it to dump.
Old Mar 14, 2017 | 08:12 AM
wrvond's Avatar
wrvond
My boat only has a 24 gallon fresh water tank. Something like this could make my life much easier on long trips.
Old Mar 14, 2017 | 08:54 AM
scraprat's Avatar
scraprat
Top Answer: 5
The bladder feels surprisingly strong for something that seems flimsy. Where space is a factor I believe this should work nicely.
That pump also is very quiet.
Old Mar 14, 2017 | 01:02 PM
wrvond's Avatar
wrvond
The product description on Amazon lists the dimensions for 30 gallons as:
36"W x 36"L x 14"H in one place and in another it's: 15.1 x 10.3 x 3.2 inches. The smaller dimensions would fit under the rear bench seat on my boat quite well, the larger not so much.
So which is correct?
Old Mar 14, 2017 | 01:23 PM
scraprat's Avatar
scraprat
Top Answer: 5
36x36x14 is the correct one.
When I added water to bladder I did have a water meter gauge on the hose so a semi accurate amount of water could be guaged as not to over/ under fill the bag. If you look at the full bag pic and notice the height compared to the hitch which is 9" from the bed to top portion of the B&W base.
Old Mar 15, 2017 | 03:24 PM
f350ktm's Avatar
f350ktm
Nice set up. 95% of our camping is dry camping and I am a bit tired of the jug routine also.
Thanks for posting the info.
Old Mar 15, 2017 | 08:12 PM
scraprat's Avatar
scraprat
Top Answer: 5
Thanks,
I just got tired of wrestling with the jugs and looking like I peed my pants after the match.
Old Mar 19, 2017 | 07:10 AM
P.Bronner's Avatar
P.Bronner
I did something very similar except I use a 55 gal. plastic (food grade) barrel secured against the front wall of the bed with ratchet straps. I also chose the same model water pump as equipped in the trailer for the reason you stated. In my case I used a 7-way plug since I have one in the bed wall, and pulled from the (+) pin for power.
Old Oct 28, 2017 | 03:14 PM
Good listener's Avatar
Good listener
I use one of these in my 7-way for my transfer pump: http://a.co/gTRHFmW . Works well, but I need to turn the ignition key on.
Old Oct 28, 2017 | 04:09 PM
scraprat's Avatar
scraprat
Top Answer: 5
Use the parking lights for power to the trailer plug no keys needed.
Old May 2, 2018 | 05:13 PM
HRTKD's Avatar
HRTKD
I'm considering getting one of these water bladders. I wanted to say thank you for the writeup and links. The AquaTank II is the one I was looking at and your recommendation confirms that.
I would send some reps your way but I've thanked you so many times it won't let me.
Old May 2, 2018 | 09:10 PM
scraprat's Avatar
scraprat
Top Answer: 5
I added a shutoff connection to the bottom hose connection of the bladder and makes it easier connecting the hose without losing water.
I found it wally world on the garden section.
Shut off valve Shut off valve
Old May 4, 2018 | 04:43 PM
HRTKD's Avatar
HRTKD
scraprat, this may be a dumb question but why do you have the sediment filter on the output side of the water pump?
Old May 4, 2018 | 05:15 PM
scraprat's Avatar
scraprat
Top Answer: 5
Good catch , I was testing the system at the time.
I don't use that filter when filling the bladder I'll use one of the
blue filters blue filters
at the faucet.
I should note that when filling the bladder I use one of these
Meter Meter
attached to the bottom of the filter then hose. It's plastic so won't take the weight of the filter/ hose hanging off of it. I have seen reviews for the meter saying it doesn't give accurate flow amount but after using it on different faucets with high/ low flow pressure it fills a six gallon jug pretty accurately everytime. There has been 1,300+ gallons put through this setup so far.
