V10 4R100 question
Old Mar 15, 2017 | 12:02 PM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
There's only so much Mark can do before you have to go out there and get dirty and start seeing if the parts he mentioned are identical.
Old Mar 15, 2017 | 12:19 PM
Powersmoke_sd's Avatar
Powersmoke_sd
Oh i plan on pulling the trans back out and checking if the parts are there. I just didn't know what to be looking for, and since i'm not up on the V10 stuff i ask questions. This whole project has been a mess.
Just want to be done with it and drive it.
Old Mar 15, 2017 | 05:12 PM
Krazee Matt
Veteran: Navy
I hear ya. I went through a couple donor trans before I found a compatible one for my build.
Old Mar 16, 2017 | 12:35 PM
Anr94's Avatar
Anr94
The flexplates should be interchangeable. I just finished swapping in a 2001 v10 into my 1999 f250 and I had to swap over the 4-lug flexplate off the 99 motor so that I could use my OG torque converter.
Old Mar 16, 2017 | 02:40 PM
utr7777's Avatar
utr7777
Question, I have a 1999 F350 V10 with the E40D/4R100 transmission, will a E40D out of 1997 150 work? This is a work truck with high miles so not wanting to put a lot into it.
Old Mar 16, 2017 | 03:45 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There is no such thing as a V10 F-150, so no, it will not work. I understand the bolt pattern is the same, and it will bolt in, but it won't shift, and if it did, it won't stand up to a V10.
20powerstroke02
Feb 14, 2017 12:06 AM
wahlturfcare
20
Sep 16, 2016 08:43 PM
sigtauenus
Jul 7, 2011 09:15 AM
artzcarz
Jul 5, 2005 04:33 AM
rancherman84
Jan 17, 2004 03:09 PM
