Offroad & 4x4
ttb to solid swap
Old Aug 30, 2003 | 07:52 PM
fordnut1985's Avatar
fordnut1985
Question ttb to solid swap
hey guys, i'm going to be swaping a dana 44 out of a 78 bronco into my 85 f-150 and need all the advice i can get on the subject. I need to know what kind of steering setup and what donor trucks i need to find any help will be appreciated thanks
fordnut85
Old Sep 1, 2003 | 04:31 PM
mooktank's Avatar
mooktank
ttb to solid swap
im using the stock 79 steering setup. Just get a 78 bronco. Use 73-77 bronco radius arm brackets.
Old Sep 1, 2003 | 07:19 PM
Ryan50hrl's Avatar
Ryan50hrl
ttb to solid swap
use the stock tie rods, and a drag link out of a 92-97 F-350 which will give you an adjustable length drag link instead of the non adjustable 79 style.
Old Sep 9, 2003 | 09:26 PM
78f3504x4's Avatar
78f3504x4
ttb to solid swap
Try a "solid axle swap" forum search, and a ton of these will come up. I put up my SAS parts list I used when I put a 78 Dana 44 under my 94 F1504x4.
Old Sep 11, 2003 | 01:30 PM
FordPerf300's Avatar
FordPerf300
ttb to solid swap
Any one thats done the SAS will help you through this, just keep asking questions and make sure you have everything you need before you start. It's not to bad, i did the whole swap by myself in about 60 hours. With help it would probably take alot less time.
Old Sep 13, 2003 | 02:56 PM
fordnut1985
ttb to solid swap
Thanx for all the good advice guys, it will go to good use. I had another idea about fabricating a 4 link or maybee a 3 link setup using HIEM joints at all mounting points for articulation, has anyone tried this before? If i went with the 3 link i would have to fab a lower mount for the shocks i think, just bouncing ideas of yall.
Thanks again for all the help
Old Sep 17, 2003 | 07:35 PM
FordPerf300
ttb to solid swap
bent and twisted sells a kit that lengthens and incorporates a heim joint onto the stock radius arms.. I'm thinking about goin that route myself..
fordnut forever
Aug 2, 2011 10:02 AM
fordnut1985
Kansas Chapter
15
Mar 19, 2010 06:56 AM
fordnut71
Electrical Systems/Wiring
Mar 15, 2004 06:21 PM
ford_nut
Jan 2, 2003 11:07 PM
fordnut85
Nov 18, 2002 08:26 PM
