Sponsored by: Real Truck
No Power Center console
Old Mar 12, 2017 | 10:23 AM
13boostedbeast's Avatar
13boostedbeast
Have a 2008 F350 Lariat Crew cab and I don't have any power coming to the center console power points. I unplugged the cig lighters and check the harness itself but no juuce. Fuse 41 and 43 test good am i missing another fuse not listed? Appreciate any help
Old Mar 13, 2017 | 12:15 PM
alloro's Avatar
alloro
Since both seem to be dead you could have a missing ground issue. Did you try testing from the center point in the socket to an alternate ground location?
Old Mar 13, 2017 | 12:20 PM
13boostedbeast
No I didn't I'll try when I get out of work and let you know
Old Mar 13, 2017 | 03:21 PM
13boostedbeast
Ok so I put the tester in the middle of the plug and grounded out to the seat bolts but still nothing.
Old Mar 14, 2017 | 09:32 AM
alloro's Avatar
alloro
Argh, yeah that would've been too simple.
Oh well here is the wiring diagram which as you can see is quite simple. Each power outlet on the console has it's own fuse, but each runs through the same 3 connectors between the fuses and the outlets.
File Type: pdf
Old Mar 18, 2017 | 01:56 PM
13boostedbeast
Finally got time to look for the connections and the one that plugs into the console was shattered. A few male and female wire end and all is good. Thanks for the help
c delisio
Jul 5, 2016 09:38 PM
gigem_aggies
Feb 18, 2013 05:17 PM
GobblinTom
6.7L Power Stroke Diesel
15
Dec 22, 2012 03:21 PM
richsoucie
Dec 13, 2008 06:09 PM
Stroked99
Sep 18, 2008 07:54 PM
