Sponsored by: Real Truck
Amber grille strobes
Old Sep 17, 2016 | 06:56 AM
Poncho450's Avatar
Poncho450
Looking to put some amber or amber/white strobes in my grille and wiring to an upfitter switch. Just for some more visibility if I'm backing my trailer from the road into a jobsite or if there is a roadside emergency. Maybe 4 lights with 3 or 4 LEDs in each.
So far the search isn't turning up a good combination of fairly good quality and fair price. Bad reviews for lower priced sets and I don't want to spend too much money for the limited use. I'm not a firefighter or EMS responder.
I figured if there were a pattern controller I'd just mount it under hood so as not to clutter up the interior and I'd simply switch the lights on/off with one of the 4 available and so far unused upfitter switches.
Has anyone done something like this?
I'm considering these Alpena models because I can grab them at a local Advance Auto. http://www.shopatlow.com/Alpena-Twin...-dd-76444.html
Old Sep 17, 2016 | 12:49 PM
Poncho450's Avatar
Poncho450
Went ahead and bought Alpena 77234 amber and Alpena 70770 white. Will attempt to run them off the same controller so that the patterns are the same. The plan is to power them from one of the upfitter switches. I've seen the body builder diagrams online for the switches, but may need to figure out how to power them off an "always hot" source instead of having the key on.
Alpena 77234
Alpena 70770
Old Sep 18, 2016 | 05:51 AM
Poncho450's Avatar
Poncho450
End result.
http://vid1193.photobucket.com/album...psu0g8vxj3.mp4
Old Sep 18, 2016 | 07:28 AM
Chuck's First Ford's Avatar
Chuck's First Ford
Looks like you got what you wanted.. Good Job.
Easy, Hard, very Hard?
Old Sep 18, 2016 | 07:55 AM
Poncho450's Avatar
Poncho450
Not bad. Took me a few minutes to figure out that I had to connect the under dash wire from the upfitter switch to one of the blunt cut wires that was blunt cut on both the inside and outside of the firewall (there are 4). But after that it was fairly easy. Thankfully someone had posted a YouTube video on where to find the blunt cuts in the engine bay as well as where to find the blunt cut ends/colors for the upfitter switch wires. His was a 2014 but they were in the same spot on the 2016. Remove the fuse block cover. Look between the rear of the block and the firewall. It was a little tight to get in there and cut the black tape that held the blunt cuts to a larger harness. Also a little tight to strip the end of the blunt after you work it loose.
Grille removal is a breeze on these trucks. I found a video on either YouTube or 1A Auto, I can't recall which. Not crazy about drilling a new truck so I used heavy duty double sided tape on the lights.
I also taped the controller next to the coolant reservoir. I'll most likely only be using the one pattern and the controller automatically defaults to the last pattern used.
Old Sep 18, 2016 | 11:02 PM
djm1204's Avatar
djm1204
so the amber strobes are new? The ones you just installed ? What about the white ones ?
Old Sep 19, 2016 | 06:12 AM
Poncho450's Avatar
Poncho450
Both amber and white strobes are new. Bought and installed the same day. Spliced them both into the same controller so that they have the same pattern. Ran them off the 10 amp upfitter switch because the paperwork with the lights claims that each set only needs 1 amp.
Old Sep 19, 2016 | 07:09 AM
Chuck's First Ford
thank you for the update.
YES the blunt wires.. as my screen name states..
when looking at this Ford last year.. at dealership.. seen all the cut wires under dashboard .. I had Major issues with this truck.. then looked at a second one.. same thing..
so I figured it was factory.... not a cut-up wire artist..
Old Sep 19, 2016 | 05:06 PM
Poncho450's Avatar
Poncho450
Yup. There are 4 blunt cuts that run through the firewall. 2 white/orange stripe. 1 solid white. 1 that's brown or gray (couldn't see it well enough) with white stripe. It's my understanding that they're a little different in gauge depending on what amperage the switch is.
There are also 4 differently colored blunt cuts that start at the upfitter switch and terminate under the steering column. One of those is what I had to connect to one of the 4 that run through the firewall to get power to my light controller.
Old Mar 18, 2017 | 01:03 PM
mzwizanski's Avatar
mzwizanski
Are your lights connected to constant power through the upfitter switch, or have power only with key on?
Old Mar 18, 2017 | 03:06 PM
Poncho450's Avatar
Poncho450
The upfitters need the key on to operate anything.
sittinlow88
53
Jan 3, 2015 08:49 PM
maverick1701
Dec 30, 2012 04:11 AM
foxv10
Jan 15, 2011 11:22 AM
Jimmy77433
2004 - 2008 F150
Nov 7, 2007 08:58 AM
frankc29
Sep 20, 2002 06:29 AM
