Oil?
Old Mar 13, 2017 | 12:19 AM
  #46
PwerStroke99's Avatar
PwerStroke99
Originally Posted by EpicCowlick
To be clear, my position is a wait and see with regards to the new spec. My opinion was formed by the first letter Ford published last fall which was very clear than ALL CK-4 oils were not approved due to insufficient wear protection. Ford even made a video with a CK-4 symbol that had a big red circle with a line through it. That left a pretty clear impression. Their opinion was based on actual testing in various diesel engines. In some other document (which I don't want to look up now) equated the new formulation to a 0W oil. That was also a flinch moment.
Step forward a couple of months and Ford releases the list you are referring to that identifies acceptable CK-4 formulations. So what changed between fall and January? Did they test each of those oils in engines or did they evaluate them some other way? Did Ford have to lower their wear standards so the new oil will pass? I have no idea but there are simply too many questions. When new information becomes available, we can take it all in then. But for now, I'm using the oil that the engine designers intended. There is no false information here, just observations.
I totally get where you are coming from, and I saw the original letter you mentioned. I would in the Fleet Maintenance industry and we have several 6.7L Powerstrokes. It definitely had me worried since I oversee the maintenance in my fleet. However, I have done a lot of research on this and I like you don't know what changed from fall to January for Ford. Maybe they educated themselves more, maybe they tested more. But they have put out a list that matches their spec WSS-M2C171-F1.
There are lots of good oils on that list.
For the record, I am still putting CJ-4 in mine because I have heard many good things about the oil I used this weekend by Lubrication Engineers.
I respect your stance, but you will be using CJ-4 until CJ-4 is no longer available and you will only be able to get CK4 which will be backwards compatible. It will still list CH-4, CI-4, CJ-4 and CK-4 on the bottles when CK-4 is fully released when CJ-4 is gone.
Old Mar 13, 2017 | 07:42 AM
  #47
oklarado's Avatar
oklarado
Originally Posted by Troy Buenger
Ford says you can use a CK-4 oil that meets their latest oil specification Ford WSS-M2C171-F1
Here's the links to Shells oil OEM Specifications that meet Ford WSS-M2C171-F1:
Shell ROTELLA® T5 Synthetic Blend Heavy Duty Engine Oil Shell ROTELLA®
Shell ROTELLA® T4 Triple Protection Shell ROTELLA®
the t4 is only approved in 10w30, and the t5 is only approved in 15w40 according to that.
Old Mar 14, 2017 | 06:04 PM
  #48
jschira's Avatar
jschira
Updated Ford statement on CK-4 oils.
Old Mar 14, 2017 | 06:05 PM
  #49
jschira's Avatar
jschira
Ford says no 10w-30 is approved.
Old Mar 14, 2017 | 06:11 PM
  #50
EpicCowlick's Avatar
EpicCowlick
The saga continues. I felt a little silly at the time I bought two years worth of of my favorite CJ-4 but not anymore. How is the uninformed public going to know about this? They are going to to go Walmart and buy oil with CJ-4 and CK-4 on the donut and think all is well. What they won't know is that the oil is not on Ford's approved list.
Old Mar 14, 2017 | 06:28 PM
  #51
jschira's Avatar
jschira
Agreed. They will buy what the manual says, which is 10w-30 CK-4 in many situations.
Old Mar 14, 2017 | 07:12 PM
  #52
K2500Z71's Avatar
K2500Z71
This situation seems pretty fluid as Ford's own list now includes some 10w-30 CK-4 oils. https://www.fcsdchemicalsandlubricants.com/main/additionalinfo/dieseloilsWSSM2C171F1.pdf
Old Mar 14, 2017 | 07:27 PM
  #53
jschira's Avatar
jschira
I guess maybe Ford changed its mind.
Old Mar 14, 2017 | 07:53 PM
  #54
K2500Z71's Avatar
K2500Z71
Who knows? Every manufacturer has their own spec these days and I suspect it's due in part to the algorithms used in the oil life monitoring systems. The algorithms likely are based upon some assumptions about the additive package and other attributes of the oil.
Old Mar 15, 2017 | 10:35 AM
  #55
2009kr's Avatar
2009kr
What are your thoughts on Amsoil?
Old Mar 15, 2017 | 10:57 AM
  #56
PwerStroke99
Fords list of approved oils will continue to grow as they test more oils. Owners are going to continue to do what they feel is best. We all know what they say about opinions.
Old Mar 15, 2017 | 10:58 AM
  #57
HRTKD's Avatar
HRTKD
For the past few years I've been a preferred customer with AMSOil. In my 1/2 ton truck almost every fluid is AMSOil. I think the coolant is the one exception. I get better MPG than most people. I test the engine oil at each oil change and the results of the test have always come back good.
AMSOil is hard to find locally, especially in a retail setting where they have the products I use. I haven't looked lately but AMSOil seems to not get actual certifications. Instead, they say they exceed the requirements for those certifications. Because of these two issues I'm seriously considering not using AMSOil in my F-350. I'm hoping that the CJ-4/CK-4 issue gets resolved soon, sometime before my first oil change. I may just take it to the dealer for the first one so I don't have to worry about it.
Old Mar 15, 2017 | 11:02 AM
  #58
PwerStroke99
There are plenty of CJ-4 oils out there still that you can use. I wouldn't hesitate in just buying some and changing the oil.
the oil im using is going to continue to use CJ-4 oil, even after they finalize their CK-4. I talked at great length with the rep yesterday at lunch. Lubrication Engineers is the brand. I used to use Schaeffers religiously in my 7.3, but tests have shown that LE oil is better.
Old Mar 15, 2017 | 11:26 AM
  #59
oklarado's Avatar
oklarado
Yikes I just looked it up. 17bucks a quart for 10-30 syn. blend. I hope its dang good stuff!
Old Mar 16, 2017 | 12:02 AM
  #60
FishOnOne's Avatar
FishOnOne
Shell Rotella T4 10W30 has the new Ford rating. I believe any CK4/SM rating will meet Ford's specification since API SM doesn't require Phos. to be less than 1,000ppm which is where Ford want it to be. On the other hand CK4/SN requires Phos. to be less than 800ppm and that's the issue.
