Exhaust help needed
Old Mar 11, 2017 | 02:21 PM
pistol22cal's Avatar
pistol22cal
Exhaust help needed
So the hubby's truck, when purchased, had the exhaust missing. Its only got the two cats and goes into a single pipe and looks like another cat. After that there is nothing. The O2 sensors are gone, is there a way to fix this without spend a fortune?
Old Mar 11, 2017 | 06:03 PM
Byoung Oh's Avatar
Byoung Oh
Shouldn't be too expensive as long as cats are good and flanges are good.
Is it missing all 2 O2 sensors or just 1 downstream?
There should be 2 upstream sensors before cats for each banks and 1 after the 3rd cat.
Sensors go around $30 to $40 on rockauto (depending on the brands).
The rest of exhaust system probably will add up to $200 or little more.
Old Mar 11, 2017 | 06:43 PM
pistol22cal
We live in an emissions free county so he can technically not use cats but if he has the sensors put in without cats will the engine light come on ???
Old Mar 11, 2017 | 08:33 PM
Byoung Oh's Avatar
Byoung Oh
Yes it will set the code.
Front 2 sensors are must as they control your air to fuel mixture. Rear sensor is for checking CAT only. The truck will run fine without it other then the CEL will be on.
On some newer vehicles (Toyota for sure), when any CEL is on, ECU goes into fail safe mode and looses some fuel economy and vehicle stability control. But, I don't think Rangers do that (made pretty dumb and simple LOL)
There is a way to avoid setting code.
You can install something like this. <title>O2 Simulator Mini Cat Cel Fix best oxygen sensor simulator made.
Get the one with honeycomb element. That will fix the CEL caused by CAT for good. Simple spacer is hit and miss. I tried that once on a SUV with bad CAT, and CEL was come and gone every few weeks.
Tried one with honeycomb element on the other SUV, never seen CEL since.
But either way, you will need a place to mount O2 sensor and probably cheaper to use existing CAT if possible and weld leaks if there are any.
I managed to plug 2 1" and 1/2" hole in my CAT with a cheap 120V harbor freight flux welder and some large metal washers as a filler metal. It wasn't easy as I was doing in on the vehicle and I had minimal experience with welding.
gravey
May 29, 2007 11:01 AM
sin
Sep 11, 2006 07:49 PM
bronconorwood
Feb 22, 2006 04:55 PM
turboguy
Exhaust Systems
Mar 11, 2005 06:40 PM
technoman26
Exhaust Systems
Feb 1, 2005 03:43 PM
