Sponsored by: Real Truck
cat trouble
Old May 26, 2007 | 08:29 AM
gravey's Avatar
gravey
cat trouble
I want to cut the cat converters off my 2001 f250 5.4L. Someone told me that I would loe back pressure and it would not run good. Is that correct? If I do this I will need to replace the sensors or my ck eng light will come on. Where do you get the dummy sensors?
Old May 28, 2007 | 07:10 AM
phil6608's Avatar
phil6608
If you cut off the 4 cats you should at least run 2 high flow cats!
That's what I did. Then you can just put the O2s back in place.
By taking off all 4 it might affect you bottom end power some.
If that's the way you must go you can get the MIL eliminators here.
http://store.summitracing.com/egnsea...=+115&y=8&x=37
Old May 28, 2007 | 06:25 PM
schmidt64's Avatar
schmidt64
My 2002 only had one cat and it ran fine after i removed it and replaced the exhaust with single 3" and a flowmaster
Old May 28, 2007 | 09:09 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Do you have an O2 sensor after the catalytic converter(s)?
If you don't, you can just hack it off.
Beware, if you are using it for business and you get inspected by DOT, you can face a heck of a fine.
And even if you won't "get caught", IT'S ILLEGAL!
Old May 29, 2007 | 09:59 AM
gravey's Avatar
gravey
Thumbs down
will it help my fuel milage any. and what about a programer?
Old May 29, 2007 | 11:01 AM
Bear River's Avatar
Bear River
Former ******
Look, the factory cat is hard to beat. To get a comparable match in flow and performance from an aftermarket high flow, would cost you. The oversize models do not have rear O2s, they use a single monster converter that is not monitored. However, its flow capablities are incredible, and most aftermarket replacements for this unit are inferior. You already have the best, so leave it alone. Thats why you bought a Ford.
Tomfo23
Sep 17, 2014 12:30 PM
HotRodTroy
2004 - 2008 F150
May 6, 2014 08:19 PM
cmalley12
6.4L Power Stroke Diesel
Jul 25, 2012 08:37 PM
perryg114
1983 - 2012 Ranger & B-Series
Jun 13, 2011 07:02 PM
fimar7
Jan 24, 2005 01:58 PM
