AOD SWAP
Old Mar 11, 2017 | 03:59 AM
Tony Ricci's Avatar
Tony Ricci
AOD SWAP
Hi everyone...im new here and was wondering....i have a 91 f150 with a 5.0 and aod trans....can i put a AOD from a 90 F150 without any mods.......any info will help.....thanks
Old Mar 11, 2017 | 09:23 AM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
AOD to AOD should present no problems......if that is what you have. E4OD made its appearance around then and was a option on the 5.0. O/D cancel button on the dash is the first clue. Also check your door jamb tag transmission option.
Old Mar 11, 2017 | 10:00 AM
Conanski's Avatar
Conanski
Yeah check the trans code on the door pillar, your truck could have one of 3 different slush boxes, an all mechanical AOD(trans code T), or the computer controlled 4R70w(Trans code U) or E4OD(trans code E).
F100Gasser
May 3, 2017 06:49 PM
preppypyro
Oct 24, 2009 03:48 PM
namdorf
May 14, 2008 09:16 AM
hotboat1
Aug 18, 2002 10:13 PM
daumer
Nov 22, 2001 11:21 AM
