EGR
Old Mar 10, 2017 | 12:28 PM
Ken Hunsucker's Avatar
Ken Hunsucker
6th Gear
EGR
Engine light on, trouble code tells me its EGR Problem. Installed new EGR valve and the light still come on. While on the FWY an 60mph or higher the light goes off. Drop below 60 and the light comes back on.
If anyone could point me in the right direction would be helpful. I have been told that the tube(metal)that connects to the exhaust(I think)could be clogged.
Old Mar 10, 2017 | 01:34 PM
rustspot's Avatar
rustspot
Trailering
I have vacuum lines on the brain this week (just posted some pics of my hose replacement), but is it possible you have a vacuum line break between the EGR and the vacuum solenoid that controls it? I see you have a 92, and if it has old vac lines they could be disintegrating.
An easy check would be to unplug the original EGR vac line at both ends and substitute a few feet of new hose. 5/32in ID ought to work.
Old Mar 10, 2017 | 01:35 PM
rla2005's Avatar
rla2005
Welcome to FTE!
It would help to know what year/model/engine truck you are working on.
Please list the code by number and when it was displayed. When displayed means during the Key On Engine Off tests, Key On Engine Running tests, or from stored codes (aka Continuous Memory).
Old Mar 10, 2017 | 05:53 PM
mdpnh's Avatar
mdpnh
I had this problem once. Vacuum leak was causing insufficient vacuum to open the EGR valve. Problem was the vacuum reservoir leaking. That's that big coffee can mounted on the right wheel well. You can get them on EBAY. BTW it's a lot easier to localize a vacuum leak if you release the tensioner and pull the belt. You won't believe how quiet an engine is without the fan and all those auxiliaries running.
Mike
1995 F150 4X4 MT 4.9L six Eddie Bauer Trim
Old Mar 12, 2017 | 10:24 AM
Ken Hunsucker
6th Gear
EGR
Didn't list vehicle info, yeah I guess that would help. It's a 1992 F350, dually , 7.5 liter. Crew Cab.Appreciate all responses will check out today. Use it a lot in summer for boat hauler. Like to have everything running proper. Try and do work myself. Saves a few bucks.
paker
1997 - 2003 F150
Mar 9, 2019 01:06 AM
CM1
Jul 29, 2008 01:07 AM
whateg01
Aug 27, 2007 09:48 AM
KraigS
Nov 13, 2006 10:00 PM
pmurry
Oct 20, 2003 01:03 PM
