Injectors HPOP or tune?
#33
So the engineers at Banks say their oiled filter flows 939CFM @ 4.29" of H2O and a cumulative efficiency of 99.6%. They claim their dry filter flows 890CFM but they don't have efficiency numbers. Those seem like great flow numbers but I don't like that they don't have an efficiency of particulate filtering on their dry element.
#35
#37
So I got everything put back together and took it for some runs with the Hydra with Gearhead tunes. I still think I have high EGTS and not a lot of power but maybe it is just how the 7.3 runs. It is my first 7.3 and am not familiar with how they run. With the tuner on the lowest 2 settings the EGTS would stay around 950 running 65 up a 6% grade no matter if the trans was in 3rd lockup or 4th.
#38
on
I would check for boost leaks first and foremost. Do you have a detector?
On this rig, I noticed that I would build boost really well until I hit about 22 psi and then it would sort of plateau with slight continual rise to about 27.
So, when I tightened everything up, I found that I had evidently not tightened one of the lower IC boots sufficiently initially. It only takes one of the twelve connection points to screw things up.
Now, the engine easily sees 27-30 psi on grades with a load. EGT's came down some too.
Next, since it is a recent rebuild, exhaust leaks are possible. Make sure the turbo to baby's butt/collector fitment is correct.
How are your up pipes? It is difficult to tell whether I am seeing shadow or soot on the firewall.
#39
#40
#41
But if your sustaining 20psi with no grade or trailer, then something is definitely dragging. Like on fire dragging. But I suspect it's the former, as that kind of drag would feel like you left the parking brake on. You, uh, didn't leave the parking brake on, did you?
#43
Minnesota is for the most part pretty flat. So my closest experience is hauling a dump trailer with my skid steer ( 14,000 lbs trailer weight) around at 70-75mph on the freeway. Don't think I ever broke 15 psi sustained going up what we call hills. That was in stock form, with some leaks. Egts we in the 1000s. With the tuner on I stay at 3-6psi at 65mph, and 9-10psi at 90mph. Which is a real treatment to the squared power wind resistance.
#44
#45
