Hello again, so my newest issue is that purchased 2 wheels for my 74 F100 SB to check fitment, I went to change wheels when much to my dismay I found that the PO changed the 5X5.5 to a 5x4.5...sigh... After speaking with him I found out going back to the stock 5X5.5 in front is easy, as he just had the rotors re-drilled, and a new set of rotors fixes that (as well I don't want to have to re-drill every time I change rotors). But the rear is another story, apparently he swapped axles and drums from a Lincoln (not sure of the year but he says it retains the stock F100 shoes). So the only way to correct this will be a new set of axles. So here are my choices, 1 return the 2 wheels and stick with the 5X4.5 all around and re-drill a new set of rotors, 2 keep the 2 wheels replace the rotors to stock and leave the back 5X4.5 (curious how this will effect payload, although I really don't plan on carrying any weight as this will be a lowered street cruiser), or 3, fix it all around. I appreciate any comments.
Thanks, Randy.
Thanks for the replies, not really concerned with wheel choice as the wheels I'm getting are available in either pattern. Unfortunately I need new front rotors, the one's on there now can't be turned again, and to keep the same 4.5 pattern means re-drilling the new rotors. So I'm thinking I'll go back to the stock 5.5 in the front for sure, my problem is that I know myself, and it will probably just bug me (no one would probably ever notice lol) having two different wheel patterns front to rear. So is it just me ? Would that be enough for you guy's to justify new rear axles? Or am I just being **** about it? LOL.
Thanks for your input.
Plus you'd need two spares, if you ran two different lug patterns.
You guys are awesome, and this is why I ask. I hadn't even considered the spare issue lol... Duh. I wasn't worried about rotation as I'll have different sizes front to rear, and at least it know I'm not the only one Unk Bob. Thanks everyone.
