Head gaskets
Old Mar 9, 2017 | 10:26 AM
Youngblood94's Avatar
Youngblood94
Head gaskets
hey I'm getting ready to build my 03 6.0 I'm putting 190cc injectors with 100% nozzles, stage 3 industrial injection turbo, blue spring, egr delete, arp head studs I might go with new manifolds too. Sinister Diesel has a kit that includes the oil cooler as well but I need to know what the best head gasket would be to use with this setup. Thanks!
Old Mar 9, 2017 | 10:40 AM
2006powerstroke90's Avatar
2006powerstroke90
Ford OEM Gaskets
Fel pro seem to have a good rep
Stay away from black oynx or any other brand
Old Mar 9, 2017 | 12:14 PM
Justus6.0L's Avatar
Justus6.0L
OEM or Fel Pro... X2
Old Mar 9, 2017 | 01:57 PM
Bumblebee04's Avatar
Bumblebee04
May want to consider a regulated return setup since you'll have the heads off. Much easier to upgrade when it's all apart. No need for the blue spring then.
Oem or felpro headgaskets. As for the heads, I'd have your originals machined. Valve seats & guides milled out & replaced with hardened ones.
Also the 03's are notorious for having a weak HPOP. Increased fuel demand will definitely work the pump harder. If it does give out, adrenaline makes the best replacement vs stocks.
Old Mar 9, 2017 | 08:37 PM
Youngblood94
i have the adrenaline hpop, forgot to mention it, i thought about sinisters fuel reg setup, any recommendation on the oil cooler id like to not go back in this thing once im done
Old Mar 10, 2017 | 06:04 AM
Bumblebee04
Excellent! Have you done a coolant flush yet? If so, was it pretty clean?
Mine was extremely neglected & full of rust when I flushed so I'm doing a diy remote air oil cooler. I know rust will eventually let loose down the road & will plug an oem oc. $2.5k in kits from bpd will give you remote air oil cooler & bypass oil filtration. I'm building my own for about $1k.
Old Mar 10, 2017 | 04:30 PM
OneCylinder's Avatar
OneCylinder
Hey Bumblebee04, I hope you start a thread when you start building your kit.
Old Mar 11, 2017 | 12:31 PM
Youngblood94
one final question 18mm head gaskets or 20mm?
Old Mar 11, 2017 | 02:50 PM
Bumblebee04
Started the parts list in my oil cooler backflush thread...
https://www.ford-trucks.com/forums/1...placement.html
18mm for 03
Old Mar 11, 2017 | 06:12 PM
Sullid01's Avatar
Sullid01
+1 OEM gaskets. With all that extra power, you should gets the heads o-ringed. I got mine from UCF machine shop - very happy with the product. +1 for regulated return. You will almost certainly need a stronger fuel pump and you should be prepared to upgrade the transmission. You are going to be making a lot more power. Post a video when you are done - track or dyno or just flying down a nice straight road
Old Mar 12, 2017 | 08:25 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
I would steer clear of anything Sinister Diesel....
It has a cool name, but that's about it, I've seen too many people have bad experiences after installing their kits for the 6.0.
If you want a regulated return, driven diesel
Makes an amazing kit and was one of the first to develop one for the 6.0. They've got it down to a fine science and people they have theirs have no regrets.
OEM headgaskets are best, but Fel-Pro headgaskets have proven themselves as well.
Since you're putting 190s to that '03 transmission, you may want to give Red Diamond Diesel a call. As BTS is to the 4R100, Red Diamond is to the 5R110. I.e. they have a "Dare you to break it" warranty.
After talking to David, the '03 transmissions have their short comings and the Excursions especially got the short end of the stick on that one.
Old Mar 12, 2017 | 09:17 AM
bismic's Avatar
bismic
Nice help for the OP! Good suggestions above for sure.
Another option on heads would be SuperDutyService!
Raz - nice to know about Red Diamond Diesel!!
Old Mar 12, 2017 | 10:26 AM
Youngblood94
ive used sinister stuff before on my 7.3 and I use their 58v ficm on my 6.0 so far I love their stuff I haven't had any problems yet, I'm still gonna shop around. Anyone have anything one warren diesel injectors?
Old Mar 12, 2017 | 11:41 AM
Toreador_Diesel
To each his own, what may work well on a 7.3 doesn't mean it's going work well on a 6.0.
Old Mar 12, 2017 | 11:50 AM
bismic's Avatar
bismic
IMO the best choice on injectors is going to be an expensive one.
OEM injectors (remanned).
If you want modified ones, I would suggest Full Force Diesel.
