2001 Ford Ranger, weird issue...
Old Mar 8, 2017 | 06:35 PM
pistol22cal's Avatar
pistol22cal
I have a 2001 Ford Ranger XL Supercab 4.0 4x4 - automatic
200000+ miles
It seems to run and drive flawless odd issue is that it will never go above 4k rpm its like thats its rev limit. Is 4k the rev limit while going down the road?
Also feels like the gas pedal is very shallow as if it can only be depressed 3/4 of the way.
If i put it in low gear it still will not rev past 4k perhaps something is wrong with the transmission shift computer???
Old Mar 8, 2017 | 09:03 PM
87 XLT's Avatar
87 XLT
Remove the tube from the throttle body and watch the throttle plate when someone floors the throttle. If it does'nt open all the way theres your problem
Old Mar 9, 2017 | 06:49 AM
pistol22cal
I found a post, related to my issue.
https://www.ford-trucks.com/forums/2...sohc-4-0l.html
Im going to tell the hubby it needs fuel filter!
Old Mar 9, 2017 | 11:07 AM
pistol22cal
The new fuel filter solved the issue!
Old Mar 9, 2017 | 11:10 AM
87 XLT's Avatar
87 XLT
Nice job doing the search, and you're right if the fuel filter is clogged it will cause the problem you are having, but since the "gas pedal can only be depressed 3/4 of the way" i would still take a quick look at the throttle body.
Old Mar 9, 2017 | 11:18 AM
87 XLT's Avatar
87 XLT
[QUOTE=pistol22cal;17017831]The new fuel filter solved the issue![/QUO, Good deal, glad to hear it's fixed.
Old Mar 9, 2017 | 01:10 PM
pistol22cal
Turns out there was a mouse nest under the dash near the pedal causing the issue. The truck will now easily melt the 32's that are on it, it is like night and day.
Old Mar 11, 2017 | 02:26 PM
87 XLT's Avatar
87 XLT
There you go, put the pedal to the metal & have some fun with it. I drive my 87 2.9 5 speed the same way.
jsiebs09
1997 - 2003 F150
May 24, 2011 06:11 PM
Farmer Bob 509
Sep 5, 2010 12:07 AM
dangerranger10
16
Mar 15, 2010 08:44 AM
Tri2Hover
20
Mar 8, 2007 10:25 PM
charlies_angel
Apr 18, 2002 08:30 PM
