460-C6
Old Mar 8, 2017 | 05:40 PM
swoosh1958's Avatar
swoosh1958
460-C6
Hey guys, Found a 76, mid 80,000 mile 460,C6 out of a Lincoln. Will that tranny hook right up to my 79, F150?
Old Mar 8, 2017 | 08:03 PM
PA74F250's Avatar
PA74F250
nope it's a 2wd trans and you have a mated 4wd setup according to your signature
Old Mar 9, 2017 | 03:57 PM
swoosh1958's Avatar
swoosh1958
That is correct. PA74f250. I thought that it may not work.
Is the 76 engine worth messing with. Someone at work said no. No horses.
Old Mar 9, 2017 | 04:06 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Internal balance: Block casting number D1VE-6015-AB, or A1B or A2B:
1971/73 Ford/Merc 429; 1971/78 Lincoln/Continental Mark III/IV/V 460; 1973/78 Ford/Merc 460; 1973/76 F100 460; 1973/78 F250/350 460; 1975/78 F150 & E250/350 460.
Some 1979 F150/350 & E250/350 460.
No: 460's in cars after 1978, in F100's after 1976.
Old Mar 11, 2017 | 06:14 PM
swoosh1958's Avatar
swoosh1958
A 1979, 460 just came up for sale. Is this worth building? External balancing?It is out of a truck. Should have all the brackets that will work. Unlike the 460 out of the Lincoln I was also considering.
Old Mar 11, 2017 | 06:53 PM
NumberDummy
A 1979 460 just came up for sale. Is this worth building? External balancing?
1979 460 could be internal or external balance.
If the block casting number is D9TE-6015-AB = External Balance, has a weighted crank spacer.
If the block casting number is D1VE-6015-AB or A1B or A2B = Internal Balance.
1979 460's installed in F150/350's (except F150's sold new in CA) and E250/350's. No car came w/a 460 after 1978.
Old Mar 11, 2017 | 07:16 PM
swoosh1958's Avatar
swoosh1958
Does internal or external make any difference when building or fitting into my truck? Other than re using or replacing the correct type of balancer?
Old Mar 12, 2017 | 09:50 AM
NumberDummy
Harmonic balancer and flywheel (flexplate) are specific to one or the other.
Jpegg01
May 20, 2018 12:36 PM
tcb168
Apr 1, 2013 07:29 AM
fslay
Nov 26, 2010 02:24 PM
jrock02301
Jun 15, 2008 08:41 PM
jer
Dec 13, 2000 05:20 PM
