Ospho rust converter?
Old Mar 7, 2017 | 01:26 PM
Brian1971f100's Avatar
Brian1971f100
Has anyone used it? I have questions. It is not a paint. It converts rusted metal and leaves a hard coating. Will it take weld? or does it burn off?
I have been looking in to rusty metal treatment and ospho seem reasonably priced compared to other products, as well as it is a one step process.
Any thoughts or experiences would be much appreciated.
Thanks Brian
Old Mar 13, 2017 | 10:57 PM
1972-34ton's Avatar
1972-34ton
Rabbit-Hole Researcher
Works on rusty metal fine, but getting down into the pits can be slow. Warmth, and brushing helps. You might look into electrolysis methods for manageable parts, first.
Phosphoric Acid leaves a milky, soapy film on top, after use. Just get that off with detergent/powerwash/chem's or whatever. It can keep primer from sticking.
It does provide some 'grab' for paint. However, you do need primer on top of it, mostly for sealing and adhesion.
As preparation, works great on top of the cab, and hoods, where the paint goes bad. It will damage good paint, so take care. Use gloves, don't mix with beer, etc.
Old Mar 14, 2017 | 05:56 AM
willowbilly3's Avatar
willowbilly3
It wont take off old patina rust. I think a good encapsulator like POR15 or Eastwoods would be better. Eastwoods is probably the best and doesn't contain isocyanides.
Old Mar 14, 2017 | 08:44 AM
Brian1971f100
Thanks for your thoughts guys. I appreciate it.
Old Mar 14, 2017 | 11:01 AM
FuzzFace2's Avatar
FuzzFace2
All good information and each has it's place to be used and yes I have used each.
I found this was the cleanest way and can also take paint off the part if you use a power washer to rinse the parts. I have done fenders & hoods the only thing that is the limit is the size of the tank!
I have also used Eastwood's paint & rust stripping pads on a grinder and it works pretty good.
I used the Eastwood encapsulator on the under side of the hood skin/frame before I put the skin & frame back together. Also did the under side of the fenders.
I don't have any pictures of using the Ospho but I used it inside doors. Sprayed it on heavy to seep into the edges & frame of the doors to "kill" any rust you cant get to with out removing the door skin from the frame to treat rust.
I also used it on the roof of my project truck because once I stripped (eastwood pad) the layers of paint & filler I found rust. It had some deep pits and only the Ospho would get into them. I let it sit 2 days to work in then sanded the area so I could use body filler as it will not stick to the chemical.
I still have to use it on the doors of this project truck.
I have also used Eastwoods inside frame coating with a long spray tube on a hood (1 year only hood and not many around now) that had no rust but wanted to coat it so it would not rust. I used it between the frame & skin as I did not take it apart like the pictures above.
This can be used anywhere between panels like windshield & door posts or roof panels that you can not get the Ospho into.
Dave ----
ps: the 2x4's where used to make benches that fold out to make table & bench http://www.2x4basics.com/outdoor-furniture.html
The 4x4 & rebar was used to make a fire wood stacker on the deck.
Old Mar 16, 2017 | 08:22 AM
Brian1971f100
Thanks for your input Dave. Nice tank you made. Bet the wife didn't enjoy the pool You say the Ospho leaves a coating that filler wont take. I was unaware of that. Thanks again.
Brian
Chiefdan
Paint & Bodywork
Mar 8, 2019 11:59 AM
ah1988
May 7, 2011 09:16 AM
53 Meadow Green
Nov 26, 2010 07:26 PM
brucers
Paint & Bodywork
Jul 1, 2004 09:38 AM
Fordication
Jan 14, 2004 05:22 PM
