Paint or primer over Extend
Old Jun 29, 2004 | 09:43 PM
brucers's Avatar
brucers
I sanded the top of my cab completely down to bare metal. The paint had been peeling badly but there were just some slight rusted areas. I then sprayed the whole top with Extend rust converter. It says let dry 24 hours before topcoat. It's drying now. I got some spray cans of plasti-cote acrylic lacquer that matches my color code and spray cans of sandable lacquer primer also from plasti-cote that is compatible with the paint. It says that primer adheres to bare metal. My questions are: will this primer adhere to the rust converter? should I scuff it up? do I even need to put on the primer? Will this paint adhere to the rust converter? If so, should I first sand with 400 grit or something? Thanks for your help, Bruce
Old Jul 1, 2004 | 09:38 AM
Scott Fraser's Avatar
Scott Fraser
I would probably scuff it with a 400. Then use the primer, a few coats should do it with very light sanding in between. Be careful not to cut through the primer down to bare metal. Then paint it. The rust converter should say weather it can be painted on or not. I know that you can paint over Rust Mort, but you have to scuff it first. In my opinion rust converting products are a waste of time. The only stuff I had real luck with is Rust Destroyer. It is a red oxide primer/ rust killer combo guarnteed to work for five years after being applied. Good luck.
