Rust-oleum rust converter
Old May 6, 2011 | 08:34 PM
ah1988's Avatar
ah1988
I was wondering if i could use that rustoleum rust converter paint on the rusty part on the body of my truck instead of sanding it , would the paint be alright to use for automotive uses would it hold up? It is a primer so after i spray that i would then put a finish coat on (color of the truck).
I would just be using it for small rust areas i am not re painting the whole truck in it. Second question is could i paint my frame and rear axle and everything else rusty under my truck with it would it hold up to the rocks, sand and grit while going down the road . I really like this stuff used it on some lawn furniture and it has held up pretty well . I am just seeing if i can take the easy and quick way out of sanding and surface prepping
Old May 6, 2011 | 10:51 PM
84-6.9L's Avatar
84-6.9L
If it were me i would still scuff it a tad. If theres rust it probably isn't smooth anyway. I wouldn't use it as a finish coat. It would work great under the truck but put a top coat no that as well. Primer isn't made to hold up to the elements, is made to help bond a top coat and not much other then that. Hope this helps
Old May 7, 2011 | 07:20 AM
ah1988's Avatar
ah1988
I was going to use it as primer and then spray the finish coat or
"topcoat" duplicolor black on it, it is going to be temporary until i can get a job and drive then i will get it painted right it s just a quick fix to stop the rust and look decent.
Old May 7, 2011 | 09:16 AM
84-6.9L's Avatar
84-6.9L
Sounds like you gots it figured out! Let us know how it goes!
Biggoomba
1947 and Older Ford Trucks
41
Nov 27, 2013 07:07 PM
Greg M-47
May 22, 2012 06:35 PM
RANGER589
18
Jun 3, 2011 10:03 AM
burnettd01
22
Oct 24, 2009 08:59 PM
dlruss
1983 - 2012 Ranger & B-Series
Sep 24, 2004 12:37 PM
