Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
When an EZ-out doesn't work?
Old Oct 1, 2003 | 08:46 PM
79blueoval's Avatar
79blueoval
The only thing E-Z outs have ever extracted for me was $$$ from my pocket.
Old Oct 3, 2003 | 10:24 PM
anomaly's Avatar
anomaly
same here.......bought one once....useless,could have spent the money on something more worthwhile....like beer.
I always just drill it out with a bit smaller than the hole,then pick out the bolt from the sides,chase the threads and you're done.It's easiest on a drill press if you can clamp it straight,but a hand drill works if you're good.
Old Oct 3, 2003 | 11:05 PM
Andysutt's Avatar
Andysutt
I have a problem with my intake manifold
It was 5/16 bolt for the water neck...
Broke it off.. drilled it, tapped it for 5/16 x 24
Still dont work....
Think I could put in a stud w/ locktight and use it that way?
Since I cant seem to get it to rethread right?
Old Oct 4, 2003 | 07:41 AM
ditch witch's Avatar
ditch witch
Andy,
You didn't say WHY it wasn't working. Is the hole off center, threads too loose? If you got the threads cut in the correct place, but they seem too loose? Use some JB Weld on the threads, screw to stud into the casting let it set up and you're good to go.
Old Oct 4, 2003 | 10:47 PM
Andysutt's Avatar
Andysutt
Thanks
I actually fixed it today. I didn't think I could drill it out any further w/o busting the "Sleeve" the FEs have in the manifold for the bolt hole.
Kinda hard to explain but you'd know it if you seen it.
But i drilled it out, retapped it w/ different threads, and it worked
Old Oct 4, 2003 | 11:00 PM
ditch witch
That's a good solution most of the time. Get a good nights sleep and regroup. The next day things just seem to go easier. I think our brains go to work solving problems while we're cutting z's!!
89gtstang
Aug 18, 2016 05:20 PM
sean23johnson
Mar 23, 2016 08:36 AM
chetspencer
Aug 31, 2015 09:57 AM
bnordgren
Sep 11, 2010 12:47 AM
Mattdad1
Apr 20, 2009 02:02 AM
