Rear differential help
Old Mar 7, 2017 | 07:48 AM
Taylor Doyle's Avatar
Taylor Doyle
OK, looking to the gods for help again. Trying to figure out what rear end I have on my 79 f150 custom 302 long bed, no tag can be found on the rear end...found #''s stamped as follows: D2SWZ668C also 6523 SF2, 6J8, and an upside down 25? It has 10 bolts around the outside.. trying to figure out what fluid to use to replace the old. Need your help thanks!
Old Mar 7, 2017 | 08:56 AM
Rollingscrapmetal's Avatar
Rollingscrapmetal
Are the bolts to the front or rear of the vehicle
the 9 inch has a third member so their bolts face to the front the Dana 44 doesn't have a third member but it has a differential cover so bolts face to the rear
Old Mar 7, 2017 | 09:22 AM
78 PEB's Avatar
78 PEB
Should be a 9" but pics would help identify it
Old Mar 7, 2017 | 09:40 AM
351Cleveland C4's Avatar
351Cleveland C4
Gear oil. You use gear oil.....
I recommend regular 85-140
As far as the axle, it's Most likely a 9" with 3.00-3.25 gears. Not that it matters for what you need to know...
Old Mar 7, 2017 | 09:54 AM
Taylor Doyle
Old Mar 7, 2017 | 09:59 AM
good to doo's Avatar
good to doo
That's a 9"
78 PEB's Avatar
78 PEB
That's a 9".......and as 351 Cleveland C4 said above......gear oil....I prefer 85W140.......
Old Mar 7, 2017 | 10:07 AM
Ozzie H.'s Avatar
Ozzie H.
I can't provide any definitive answer. The Ford truck shop manuals have a lot of ID information in them (but I don't have the ones from '79). I'm guessing a bit, but it sounds like it "might" be a Ford axle with a 9" ring gear. The one in my '76 F-250 has a tag attached between two of the cover bolts on the driver's side, but it is a Dana.
The ratio there is 3.07:1.
If you're wondering about ratio, the surefire way is to remove the cover and count teeth (in case you're not the original owner).
As far as the lubricant goes, in '76, it was hypod gear lubricant with Ford part number C6AZ-19580-B or equivalent meeting Ford specification ESW-M2C105-A for a non-limited slip differential. For the "Traction-Lok" axles, the numbers changed to C9AZ-19580-A and ESW-M2C119-A. To tie it down a bit better for '79 you could look in a '79 Ford truck shop manual (vol.5?) or search the technical information portion of this forum.
Old Mar 7, 2017 | 10:11 AM
good to doo
The only way to drain the oil on it is to pull it apart. Add a drain plug at the same time.
TKKTommyboy
Oct 4, 2006 08:35 PM
jjoker023
Apr 25, 2004 12:56 PM
Cmotif
Jan 2, 2004 10:14 AM
blueoval79
Apr 30, 2003 09:31 AM
BubbasRacing
Sep 3, 2002 06:22 PM
