Torque pro pid help
Old Apr 1, 2017 | 05:57 PM
sdetweil's Avatar
sdetweil
Originally Posted by MPD56
Hey Sam
Just to ADD.
My 2013 readings don't match the dash either. And my Torque Pro PID doesn't match the the started and stopping at 0% and 100% after a PCM update. There is a few resasons for different model years to not match, one examples is that some uses different sensors and the Soot Levels are really just a equation of the back pressure in the DPF. I have changed the equation for my 2013 and friends 2015 Soot% but haven't had time to verify it and when I do, I will post it.
once we get confirmed equations, I can update the apk and add year specific PIDs as required..
Old Apr 1, 2017 | 07:49 PM
onequicksportster's Avatar
onequicksportster
Originally Posted by sdetweil
I just downloaded and re-installed the plugin, and all the entries in the list are loaded on my samsung tablet.
I cant find ECT, DPF on and off, or DPF soot level? I cant figure out what I'm doing wrong.. Heck I've even got the tpm working, oil temp, and others..
Old Apr 1, 2017 | 10:12 PM
sdetweil's Avatar
sdetweil
ect is "Engine Coolant Temperature ECT 1 6.7L"
you DID add JUST the 6.7 pids, right?
there are some built in other FORD pids, which are NOT ours..
every entry for this plugin has 6.7L at the end of the name
Old Apr 1, 2017 | 10:44 PM
onequicksportster
I open torque pro, go to plugins, scroll to the bottom, pick ford superduty 6.7..
Old Apr 2, 2017 | 05:51 AM
sdetweil's Avatar
sdetweil
great.. just checking for possible causes why you might not see some of these sensors when you do Add Display
Old Apr 2, 2017 | 08:39 AM
onequicksportster
great.. just chekcing for possible causes why you might not see some of these sensors when you do Add Display
Dude thanks!!! I re download it and now I have all the PID's
I appreciate the help!!
Old Apr 2, 2017 | 10:00 AM
sdetweil's Avatar
sdetweil
woohoo.. great news.. thanks for the feedback
Old May 11, 2017 | 10:13 PM
wb6anp's Avatar
wb6anp
Has any one been able to get the DPF% to work at all on the '17 6.7? I have the plugin and DPF doesn't work.
ReddTruck
2004 - 2008 F150
15
Nov 17, 2019 03:29 PM
cdnfireman
6.2L V8
Aug 3, 2018 11:28 PM
krobbins
Apr 8, 2018 11:36 AM
speedracer1000
Sep 27, 2009 02:13 PM
